Maniphest T7423
Select Grouped works only for "active" object
Closed, Archived
Ton Roosendaal (ton)
Juho Vepsalainen (bebraw)
Sep 27 2007, 6:43 PM
  • BF Blender
Resolution: Investigate
Category: Tools
See attached .blend. Try selecting one object from both groups and then invoke shift-g -> objects in same group. Note how objects only from the group of the "active" object are selected. Another interesting thing to note is that the behavior is the same for shift-g -> children. You can see this by selecting the parents of the cones and invoking the command.
These cases should work so that they do the selection for all selected objects instead of just "active" one. The old way of selecting still works in this case but only if one object is selected.
Juho Vepsalainen (bebraw) edited a custom field.Sep 27 2007, 6:43 PM
Juho Vepsalainen (bebraw) attached 1 file(s): F4412: selbug.blend.
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Nov 25 2007, 8:03 PM
Nobody (None) added a comment.Sep 27 2007, 6:43 PM
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
Diffusion mentioned this in rPc6a7bf87294d: Make similar/subtask actions clickable.Mar 6 2015, 4:54 PM
