Maniphest T7862
Sequencer - Force Orginal Size Image
Closed, ArchivedPATCH
Peter Schlaile (schlaile)
Wojciech Kupiec (wojak)
Dec 2 2007, 11:09 PM
  • BF Blender
Hi All
I'm working on new functionality in Image strip properties.
New button "Orginal Size" have been added. When button is pressed Offset X and Y is possible to set.
By default when new image strip is added, image is scaled to render image size.
It was problem for may everyday work, because wenever i want to add smaller image than render window - like my logo I had to use transform strip to rescale image to orginal size or make image in orginal size to avoid scaling.
Now I can only press button and set Offset - This is simple solution for simple efect.
Please take a look at attached files:
seq_orginal_size_01.diff - patch
sequencer.jpg - secuencer
nosize_render.jpg - oryginal effect
size_render.jpg - render with forced orginal size
Wojciech Kupiec (wojak) edited a custom field.Dec 2 2007, 11:09 PM
Wojciech Kupiec (wojak) attached 1 file(s): F5380: seq_orginal_size_01.diff.
Wojciech Kupiec (wojak) attached 1 file(s): F5381: sequencer.jpg.
Wojciech Kupiec (wojak) attached 1 file(s): F5382: nosize_render.jpg.
Wojciech Kupiec (wojak) attached 1 file(s): F5384: size_render.jpg.
Wojciech Kupiec (wojak) attached 1 file(s): F5385: seq_orginal_size_03.diff.Dec 6 2007, 11:33 PM
Peter Schlaile (schlaile) changed the task status from Unknown Status to Unknown Status.Jan 8 2008, 9:51 AM
Campbell Barton (campbellbarton) mentioned this in T54387: 2.8: Code-Quest (Topics we plan to cover).Mar 21 2018, 12:21 PM
