Maniphest T19794
Sequence editor preview and anim render output broken on Linux PPC (again)
Closed, Archived
None
Anders Gudmundson (anders_gud)
Nov 2 2009, 10:40 PM
  • BF Blender
None
Group: V 2.49b release
Category: Sequencer
Hi Peter!
Resurrecting my old G4 laptop :-)
Endian problems somewhere it seems... This screenshot is from Debian squeeze PPC - I also got the same problem when building 2.49b from svn in Debian lenny (used make as scons had problems with x264 and undefined altivec symbols)
Cannot try on OS X PPC as the builds on blender.org are lacking FFMPEG.
Btw. sound in dv renders is choppy can it be related?
Some info on input (blender -d):
Input #0, dv, from '/home/anders_hardy/Desktop/video/video005.dv':
Duration: 00:00:22.36, start: 0.000000, bitrate: 28800 kb/s
Stream #0.0: Video: dvvideo, yuv420p, 720x576, 28800 kb/s, PAR 59:54 DAR 295:216, 25 tbr, 25 tbn, 25 tbc
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[swscaler @ 0x12a0c440]ALTIVEC: Color Space ABGR
[swscaler @ 0x12a0c440]using unscaled yuv420p -> bgr32 special converter
Anders Gudmundson (anders_gud) edited a custom field.Nov 2 2009, 10:40 PM
Nobody (None) changed the task status from Unknown Status to Unknown Status.Nov 2 2009, 10:40 PM
Anders Gudmundson (anders_gud) attached 1 file(s): F9154: Skärmbild.png.Nov 2 2009, 10:40 PM
Anders Gudmundson (anders_gud) added a comment.Nov 3 2009, 5:58 PM
Aah - forget it! There was a FFMPEG library mismatch (debian-multimedia.org). All is OK now with only Squeeze repos.
Why do Debian and Ubuntu link with system libs - I thought Blender used statically linked ffmpeg from extern?
Anders Gudmundson (anders_gud) added a comment.Nov 5 2009, 11:55 AM
This happens when you build from source and use the bundled ffmpeg on Debian PPC, reproduced now on Squeeze
Anders Gudmundson (anders_gud) attached 1 file(s): F9156: writeffmpeg.c.diff.Nov 5 2009, 8:50 PM
Anders Gudmundson (anders_gud) attached 1 file(s): F9157: Makefile.diff.
Checked out FFMPEG current (20464) to extern - now preview works but rendered movies are red. Disabling RGBA-conversion and flipping in writeffmpeg.c does the trick! Output seems ok...
Had to change the Makefile in extern/ffmpeg (new configure options)
patches included.
Tom Musgrove (letterrip) added a comment.Mar 21 2010, 6:13 AM
Nobody (None) added a comment.Nov 2 2009, 10:40 PM
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
