Maniphest T22701
Object Property Chart
Closed, Archived
mindrones
Jun 30 2010, 10:27 AM
  • Add-ons (Community)
Satish Goda (satishgoda)
Project: Blender Extensions
Tracker: Py Scripts Release
Blender: 2.64
Script name: Object Property Chart
Wiki page: http://wiki.blender.org/index.php/Extensions:2.5/Py/Scripts/System/Object_Property_Chart
Author(s): Campbell Barton (ideasman42)
Category: System
SVN Download: https://svn.blender.org/svnroot/bf-extensions/trunk/py/scripts/addons/system_property_chart.py
Status: Open
Related: 25584
* Put the script in \\.blender\scripts\addons if it's not there already.
* In User Preferences you can see the Add-Ons menu.
* You can activate the script here.
* From now on, selecting an obejct you will see a new section in the Properties panel in the 3d view (N-panel).
* In that section you can edit selected objects properties
mindrones edited a custom field.Jun 30 2010, 10:27 AM
Brendon Murphy (meta-androcto) added a comment.Oct 15 2010, 12:09 AM
working revision update
rev: 32411
ronan ducluzeau (zeauro) added a comment.Dec 4 2010, 3:41 PM
ubuntu 10.04 64bits rev33470
Property Chart panel in 3DView properties is empty.
Nobody (None) added a comment.Mar 21 2011, 10:02 PM
On Windows XP Pro 2.56aB : I see nothing as shown on attached screenshot.
Nobody (None) added a comment.Mar 22 2011, 3:19 PM
I did see HUNDREDS of this same RUNTIME ERROR reported in my Info window:
"Traceback (most recent call last):
" File "C:\PROGRA~1\BLENDE~1\BLENDE~4\Blender\2.56\scripts\addons\system_property_chart.py", line 79, in _property_chart_draw
" strings = id_storage[self._PROP_STORAGE_ID] = "data data.name"
"RuntimeError: Writing to ID classes in this context is not allowed: Scene , Scene datablock, error setting Scene.view3d_edit_props
"location:<unknown location>:-1
Being not really conversant with Python, and even after reading the code not quite knowing which valuable services i was supposed to get from it, I disabled this addon for the time being.
Brendon Murphy (meta-androcto) added a comment.May 22 2011, 1:52 AM
Hi!
Since your script is now in bf-extensions\' svn (contrib|trunk) we have deleted the current attachments to avoid that end-users could reach this page and get the wrong version of your script.
Note that your script may have api changes or small maintenence changes applied in SVN.
Please retrieve your script from SVN before updating SVN to avoid mis-versioned scripts.
Thanks!
Brendon Murphy (meta-androcto) added a comment.Feb 21 2012, 10:16 PM
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
Nahuel Belich (belich) added a comment.Oct 26 2013, 9:58 PM
Hi it seems that the link at http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/System/Object_Property_Chart to download the addon its aiming to a diferent url.
//trunk/py/scripts/addons/system_property_chart.py at the moment at the wiki add on list the path is //trunk/py/scripts/addons/space_view3d_property_chart.py
thanks
Nobody (None) added a comment.Jun 30 2010, 10:27 AM
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the Add-ons (Community) project page for more information on the workflow.
Nobody (None) changed the task status from Unknown Status to Unknown Status.Jun 30 2010, 10:27 AM
Satish Goda (satishgoda) added a subscriber: Satish Goda (satishgoda).Jun 26 2017, 7:50 AM
