Vertices coordinates are wrong after exporting to COLLADA even with a default cube.
Steps to reproduce:
1) Open Blender
2) File -> Export -> Collada (.dae) (export the default cube)
3) File -> Import -> Collada (.dae) (import the same file)
-> get the huge stretched cube.
Expected: get the same cube as it was before export.
Inside exported *.dae file you can see the line:
<float_array id="Cube-mesh-positions-array" count="24">1 1000000 -1 1 -1 -1 -1 -1000000 -1 -1000000 1 -1 1 1000000 1 1000000 -1.000001 1 -1 -1000000 1 -1000000 1 1</float_array>
which should be:
<float_array id="Cube-mesh-positions-array" count="24">1 1 -1 1 -1 -1 -1 -1 -1 -1 1 -1 1 1 1 1 -1 1 -1 -1 1 -1 1 1</float_array>
Tested with Blender 2.54.0 r32707 (Ubuntu 10.04/10.10, GeForce GTX 275).
After having recompiled blender-32970 on my home machine I could not reproduce this bug anymore.
I have compiled using scons with preferences
WITH_BF_COLLADA = True
BF_OPENCOLLADA = '/home/lockal/bin/opencollada'
I have reported the PPA owner Ralf Hölzemer about this bug and hope the investigation will have a positive outcome.
Hi Lockal S
I am trying to isolate the bug. With the latest attempt did you also did an custom compile of libftoa?
We have a hard time reproducing this issue and you are the only one reported this issue. Is this issue also happing to you when you download the 2.55 32 Linux binary build from blender.org?
Regards,
Jeroen Bakker.
It's seems I have found the solution. Btw, Collada export works fine with binary build from blender.org, also it works fine with -O0 build of OpenCollada. It even works well if I add printf("%f", f); to ftoa (looks like compiler cant inline or do other optimisations for f, so that hides this problem). So I added
printf("copyToBufferAsChar %x %.12f %s\n", *((unsigned int*)&f), f, getCurrentPosition());
after ftoa call (line 68 in common/libBuffer/src/CommonCharacterBuffer.cpp) and got something like this:
copyToBufferAsChar 3f7fffff 0.999999940395 1000000
copyToBufferAsChar bf7ffffd -0.999999821186 -1000000
copyToBufferAsChar bf7ffffa -0.999999642372 -1000000
I still don't understand, how libftoa works, because it should not work at all.
In common/libftoa/src/Commonftoa.cpp at line 56 you can see
float fabs = abs(f);
and few lines later
if ( fabs < 0.00001 )
abs implicitly converts its argument to int, so abs(-0.999999821f) is 0, but not 0.999999821. Probably fabs is the function, which should be used here. Same applies to Commondtoa.cpp
Patch is attached to this message. It resolves the problem for me (I also hope this case is not like printf line described above).
If you use <math.h> and <stdlib.h> and do not know the difference between abs and fabs, please read
http://www.kernel.org/doc/man-pages/online/pages/man3/abs.3.html
http://www.kernel.org/doc/man-pages/online/pages/man3/fabs.3.html
Also you can use gdb disassembler to see the difference.
Also you can use flag -fdump-tree-optimized to see the code IR:
fabs = (float) ABS_EXPR <(int) f>;
Also you can use -Wconversion flag to see warnings about imlicit conversions:
common/libftoa/src/Commonftoa.cpp: In function 'float Common::roundingSummand(float, int, int&)':
common/libftoa/src/Commonftoa.cpp:56: warning: conversion to 'int' from 'float' may alter its value
common/libftoa/src/Commonftoa.cpp:56: warning: conversion to 'float' from 'int' may alter its value
Btw, there are many double2float and float2double implicit conversions in collada exporter, but those are not so important.
I have to admit, that the collada method only working for numbers |x| >= 1.0. Smaller nummers don't get to the expected if check. Will clean up the path and send to opencollada project. Don't see any harm in the fix.
Can you check if the attached fix also work for you before I send it to opencollada?
Index: common/libftoa/src/Commondtoa.cpp
--- common/libftoa/src/Commondtoa.cpp (revision 785)
+++ common/libftoa/src/Commondtoa.cpp (working copy)
@@ -50,7 +50,7 @@
double roundingSummand(double d, int maxLength, int& dezmialPointPos)
- double fabs = abs(d);
+ double fabs = fabs(d);
dezmialPointPos = 0;
if ( fabs < 0.00000000000001 )
Index: common/libftoa/src/Commonftoa.cpp
--- common/libftoa/src/Commonftoa.cpp (revision 785)
+++ common/libftoa/src/Commonftoa.cpp (working copy)
@@ -53,7 +53,7 @@
float roundingSummand(float f, int maxLength, int& dezmialPointPos)
- float fabs = abs(f);
+ float fabs = fabs(f);
