Maniphest T25541
Inner polygons (vertices, edges) are visible through outer polygons in Blender 2.56a
Closed, Archived
None
Mike (johnybgood)
Jan 8 2011, 10:06 AM
  • BF Blender
  • Modeling
Mike (johnybgood)
Ton Roosendaal (ton)
In the edit mode inner polygons (vertices, edges) are vesible through outer ones. In the attaced files there are scrrenshots of cube with extruded inside poligons and blend file. On the first screenshot you can see what i mean. Maybe it is not bug, but It is not convenient to work with this. This bug was also in Blender 2.54.
Mike (johnybgood) edited a custom field.Jan 8 2011, 10:06 AM
Mike (johnybgood) attached 1 file(s): F15651: 1.JPG.
Mike (johnybgood) attached 1 file(s): F15652: cube.blend.
Ton Roosendaal (ton) added a comment.Jan 8 2011, 1:43 PM
Set the "clip end" value to lower than 5000, as is default now. For camera itself as well as for the 3d window (it's in the 3d window, properties with NKEY)
Ton Roosendaal (ton) changed the task status from Unknown Status to Archived.Jan 8 2011, 1:43 PM
Mike (johnybgood) added a comment.Jan 8 2011, 3:27 PM
Thank you. Sorry for this, it is not bug :)
