Maniphest T25897
Issue comments are off to one side under IE9 Beta
Closed, Archived
Nathan Letwory (jesterking)
Andrew McDonald (myrmecophagavir)
Feb 1 2011, 7:46 PM
None
Project: projects.blender.org
Tracker: Bugs
Category: Interface
Status: New
When browsing the Blender bug trackers with Internet Explorer 9 Beta, the comments are shifted off to one side. See attached screenshot.
I don't know if this is a bug in the tracker's code, or IE9. If the latter, it could be reported at http://connect.microsoft.com/ie/
Andrew McDonald (myrmecophagavir) edited a custom field.Feb 1 2011, 7:46 PM
Nobody (None) changed the task status from Unknown Status to Unknown Status.Feb 1 2011, 7:46 PM
Andrew McDonald (myrmecophagavir) attached 1 file(s): F17245: Offsets.jpg.Feb 1 2011, 7:46 PM
Valter Battioli (valtervb) added a comment.Mar 6 2011, 5:03 PM
Also with IE9 RC
Valter Battioli (valtervb) added a comment.Mar 15 2011, 10:12 PM
Is the same with official release
Andrew McDonald (myrmecophagavir) added a comment.Mar 16 2011, 1:13 PM
This has been open for over a month now, could we get a comment from whomever's writing the bug tracker code? Is there any estimate on when this will be fixed, or even any exploration of whether the issue is in the site code or IE itself?
Nathan Letwory (jesterking) added a comment.May 9 2011, 12:23 PM
I don't have IE9 so I can't verify nor fix. If someone can look into the CSS and see if a local fix can be found, that'd be great.
Nathan Letwory (jesterking) added a comment.May 9 2011, 12:33 PM
This is actually a duplicate of [#23577]
Nathan Letwory (jesterking) added a comment.May 9 2011, 3:01 PM
Sorry, typoed there. Should be: [#25337]
Valter Battioli (valtervb) added a comment.May 9 2011, 10:04 PM
I think that the problem is about the "Document Mode":
"This behavior matches that of Internet Explorer when rendering a document with no doctype or a Quirks doctype. It's similar to the behavior of Microsoft Internet Explorer 5 and the Quirks mode behavior of Internet Explorer 6, and the same as the Quirks mode of Internet Explorer 7."
I don't know exactly what I have wrote :) but if I change Document mode from "No standard" to "Internet Explorer 8 Standards" or "Internet Explorer 9 Standards" I can see the page correctly.
Valter Battioli (valtervb) added a comment.Jun 20 2011, 10:10 PM
maybe here the solution: http://msdn.microsoft.com/en-us/library/gg699338(v=VS.85).aspx
When I load a page from the tracker the Document mode of the browser is "No Standard". If I force to "IE9 Mode" I can see correctly the page.
So you must add <!DOCTYPE html> ?
Nobody (None) added a comment.Feb 1 2011, 7:46 PM
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
