When pressing Ctrl+Shift+Alt, the Shift key stays in a pressed state. This seems to occur in every type of window. This bug may have some relation with this one : http://projects.blender.org/tracker/index.php?func=detail&aid=25476&group_id=9&atid=498
To get out of this state the user must press Shift again. This brings many confusing situations.
System : Windows Vista 64 on a 32 bit machine (also occured on Windows Vista 32 on another 32 bit machine)
rev : 35116, It also occured at rev. 34116 (yes exactly 10 000 rev. ago! but maybe older)
Sytem-info is attached.
Steps to reproduce :
-Open Blender
-Press simultaneously Ctrl+Shift+Alt keys in any window
-Then in the 3d view, middle click and move the mouse to rotate the view
-Notice that the view is not rotating but panning (Shift again to get out of this state)
Also Notice in System-info that bpy.app.build_revision returns -UNKNOWN- instead of the revision number. This occurs since at least 34995.
Ok, I forgot to mention something. I work on a laptop with a usb keyboard. With that setup the bug occurs 100% of the time. If you have one close, you could try to see if you get a better ratio. I tried it with the laptop keyboards and it is still possible to do it on both systems, but at a lower ratio. It seems to be easier to replicate with the slower computer. Here are the specs of my computers to give you an idea: core 2 duo 2GHz, Pentium dual cpu 1.46GHz
To facilitate replication, you can do Ctrl+Shift+Alt directly in the 3d view. And sometimes it is Ctrl that stays pressed and keep zoooming. But Alt never did it, at least it never made the view point to snap.
I attached the patched.
PeekMessage 'ate' WM_SYSKEYDOWN & WM_SYSKEYUP messages which were in between WM_CHAR < WM_SYSDEADCHAR.
Dunno, removing messages is not really necessary as commands like WM_CHAR are skipped anyway.
I had idea to use ToAsciiEx, but then Blender never has proper Keyboard status.
Easier way to test this bug:
Open Task Manager
Right click on Blender
->Set Priority -> Low
-> Set Affinity -> to only one CPU
Try to press Ctrl + Shift + Alt simultaneously several times
Anyway keyMsg.wParam returns UTF-16. Ideally it should be converted into UTF 8 with 4 char array with WideCharToMultiByte, but GHOST messages do not support UTF8 yet. Therefore ascii should be clipped to be compatible with UTF-8.
