Category: Animation
The when you play an action animation with an ping pong action actuator then it looks like that it is working.
But when you trigger the animation a second time (or very fast multible times) while the animation is playing, the animation did not play to the end frame or start frame.
Also when you connect a always sensor (with enabled true pulse) then the animation did not play as in Blender 2.59.
