In old compositor, connection from color output to scalar number input simply converts RGB to brightness, however afer tile branch merge it seems to convert to brightness*alpha so the results of post processing will be much different from older ones.
I don't know if this change is intended, but it should irritate us because we have to modify the node settings in most of all older .blend files.
r46794
Ubuntu 12.04 amd64
