Maniphest T31581
UVs get broken when the option "correct uvs" its used
Closed, Resolved
Antonis Ryakiotakis (psy-fi)
Nahuel Belich (belich)
May 24 2012, 5:20 AM
  • BF Blender
Andy Davies (metalliandy)
Sergey Sharybin (sergey)
Relates to: T31951
As you can see in the attached picture, when the loop its slide or if a loop cut its done using the "Correct uvs" option, the vertex at the uv editor will be splitted, they move just a bit but its enough to generate some issues, with the selection and the subsurf modifier.
1- create a mesh
2- do a uv map , any one will work
(a grid and a unwrap its the simpliest)
3-select a loop at edit mesh
4- Use "Slide edge"
5- at the operator menu activate "correct uvs" ( at tool shelf or F6)
5B- create a new loop using "loop cut and slide" (Ctrl+R) if you ar using this remember to activate the option "correct uvs" under the "input" menu at the "User Preference" . Its Disable by default and the operator dosnt have redo so it needs to be active before cut.
6-check the uvs at the uv/image editor
you should find that the vertex slided and the neighbours were splited.
Tested on:
Windows 7
blender 2.63a official
and build from graphicall rev 46913
but this remain the same since 2.62 i cant remember exactly witch revision, probably after bmesh
Another thing I found this report, http://projects.blender.org/tracker/index.php?func=detail&aid=29771&group_id=9&atid=498 its near but its not the same thing
Related Objects
Mentioned In
rB9d5e5e282cff: Calculate epsilon values for interp_weights_poly to improve accuracy
rB4464a9425be9: Calculate epsilon values for interp_weights_poly to improve accuracy
D7772: Calculate epsilon values for interp_weights_poly to improve accuracy
Nahuel Belich (belich) edited a custom field.May 24 2012, 5:20 AM
Nahuel Belich (belich) attached 1 file(s): F19843: moved_uv.blend.
Nahuel Belich (belich) attached 1 file(s): F19844: system-info.txt.
Nahuel Belich (belich) attached 1 file(s): F19846: moved_uv.jpg.
Antonis Ryakiotakis (psy-fi) added a comment.May 24 2012, 6:44 PM
Confirmed. I think the correction is done with a strange hack using projected geometry. Currently I am working on new code to correct uvs in the bratwurst branch so it may be fixed there. We'll have to see.
Andy Davies (metalliandy) added a comment.May 24 2012, 7:15 PM
It would be nice if the correct UV's option was enabled by default. I didnt even realise it was there until now. I can't see any reason for people not wanting correct UV's if they are adding a loop to a mesh that already has UV's. :)
Sergey Sharybin (sergey) added a comment.Jun 18 2012, 12:52 PM
Closed duplicate report: http://projects.blender.org/tracker/index.php?func=detail&aid=31859&group_id=9&atid=498
Assigning to Antony due to he's working on this :)
Antonis Ryakiotakis (psy-fi) added a comment.Jun 27 2012, 2:04 PM
Hi, sorry for not replying for too long. I am going to work on this code now because I may need to hook my UV transform correction code there. Anyway, I think the bug is easily explained: Each loop must be projected separately on a face. I will probably fix this by searching for an optimal face first and flushing the result to all coincident loops, just as I do for my new uv transform correction code.
Antonis Ryakiotakis (psy-fi) added a comment.Jun 27 2012, 7:14 PM
The uv behaviour is fixed in r48340. However this bug exposed that this behaviour will happen on every loop customdata probably. We will have to eventually find a more general way to do it.
Nahuel Belich (belich) attached 1 file(s): F19851: sphere_test_rv48341.blend.Jun 27 2012, 8:29 PM
i have tested using a custom build rv48341 ((from oscurart) for windows x64, and the uvs are no longer ditorted but the last vertex at the seam become welded. . im not sure if welded is the rigth word.
i have attached a jpg and a blend file ( name_rv48341)
Nahuel Belich (belich) attached 1 file(s): F19853: sphere_test_rv48341.jpg.Jun 27 2012, 8:29 PM
Antonis Ryakiotakis (psy-fi) added a comment.Jun 27 2012, 9:30 PM
This has happened before though as far as I know? It is a bug and should be corrected but I will take care of it after I have prepared my code for GSOC which deals with this problem.
Nahuel Belich (belich) added a comment.Jun 27 2012, 10:06 PM
I just tested it using the official 2.63a from blender.org and it breaks the uvs, that little offet, but doesnt weld anything near the seam.
Antonis Ryakiotakis (psy-fi) added a comment.Jun 27 2012, 10:41 PM
I have tested again and it does weld them in 2.63a as well. In the second file with the sphere, the UVs are already coincident that's why there's no difference. If not, could you post a file that shows seam uvs staying separated after transform correction? Note, make sure to refresh the image editor by zooming after the transform to see the updated result. I am almost certain because there's even a comment in the code about that and I have tested it.
Nahuel Belich (belich) attached 1 file(s): F19855: test_rv_46461.jpg.Jun 27 2012, 11:30 PM
added a new jpg, do i do a new test file with the official build?
i just move an other edge from the sphere
Antonis Ryakiotakis (psy-fi) added a comment.Jun 27 2012, 11:58 PM
OK, I see it now, investigating.
Antonis Ryakiotakis (psy-fi) added a comment.Jun 28 2012, 6:58 PM
Hi, this is not so straightforward to solve. I working on the same problem in bratwurst in a way that will solve the problem for more transform modes and support islands as well,
Antonis Ryakiotakis (psy-fi) added a comment.Jan 7 2013, 10:46 PM
Fixed, r53641. Better before bratwurst merge since it's quite a nasty bug.
Antonis Ryakiotakis (psy-fi) changed the task status from Unknown Status to Resolved.Jan 7 2013, 10:46 PM
Sebastian Parborg (zeddb) mentioned this in rB4464a9425be9: Calculate epsilon values for interp_weights_poly to improve accuracy.May 25 2020, 6:59 PM
Jeroen Bakker (jbakker) mentioned this in rB9d5e5e282cff: Calculate epsilon values for interp_weights_poly to improve accuracy.Jun 11 2020, 8:39 AM
