I tried to apply the function according to the documentation in this article:
http://wiki.blender.org/index.php/User:Jason_hays22/GSoC-2011
It either does not work at all, or it is not correctly documented.
At least the documentation left it open what the tool realy does :(
How to reproduce:
- take any weighted object.
- go to weight paint mode.
- enable multi paint mode.
- select a set of vertices.
- try to apply Weights -> Fix Deforms
Nothing happens.
Expected behaviour:
vertex weights and/or vertex locations should change with changing the operator values of the tool.
I have not added a blend file as i have no idea what i should put into it in this case.
Related Objects
Related Objects
- Mentioned In
- rB9d269a97be52: Fix "Fix Deform" not working in Blender 2.8
T60517: New vertex groups cannot be operated upon ... until?
