Windows8Pro64bit + GeForce GTX 660
occurs on 2.65a
If a strip on NLA moved long distance (especially longer than 10,000 frames) , its scale is changed.
1. create a NLA strip. (attached file)
2. press G-key then input 10000 then press Enter.
3. now you can see longed strip.
(though if mouse is moved after input the number and before press Enter, the bug is gone.)
Related Objects
Related Objects
Assigning to self.
Chances are the problem occurs because the new start position gets set before the new end does: thus, the start value is clamped to the old end value, while the end value can be set properly. Accordingly, the scale value is increased to fit the new strip extents.
This problem usually won't occur when using mouse transforms as it's generally not that easy to move strips fast enough to cause problems.
