Windows 7, 64bit, GeForce GT 555M
Broken: Blender 2.69 r60995
Worked: Blender 2.69 r61240
Blender crashes in some unexpected situations
Open the attached file and
- click X then Dissolve Vertices - crash (not always)
if not then
- pan and rotate view then click X then Dissolve - crash (not always)
I've encountered that it's possible to avoid crash in first situation. Open the file and before dissolving rotate/pan view. It helps in some situations. Vertices leading to crash are red marked.
On the Grease Pencil panel there is second, green marked layer. Try to dissolve marked vertices one by one (order of dissolving is not important). To make things more complicated it works in r60995 and is broken in r61240.
