Maniphest T37953
Separate sun lamp size as angular diameter
Closed, ResolvedTO DO
Rachit Jain (j-rachit)
Brecht Van Lommel (brecht)
Dec 26 2013, 4:56 PM
  • Render Pipeline
  • BF Blender
  • Cycles
  • Good First Issue
Aaron Carlisle (Blendify)
Mayur Odedara (maxyodedara5)
ming liu (lunitari)
Robert Fornof (amdbcg)
Samarth Mediratta (samarthmed)
Tim Stullich (tstullich)
The sun lamp Size property in Cycles and Blender Internal is currently shared with point, spot and area lights. However as these lamps are rendered as if infinitely far away, it makes no sense to specify them in meters.
Rather you should be able to specify an angle instead. For example the real sun as seen from earth has an angular diameter of about 0.526° to 0.545°.
http://en.wikipedia.org/wiki/Angular_diameter
Implementation of this involves:
  • Add a new sun_size property and give it a default value roughly the size of the real sun.
  • Change the Cycles and Blender Internal code to use an angle (figure out conversion formula, this requires some math skills).
  • Add a version patch in do_versions to convert the existing lamp size to an angle for backwards compatibility.
Revisions and Commits
Related Objects
Brecht Van Lommel (brecht) created this task.Dec 26 2013, 4:56 PM
Brecht Van Lommel (brecht) renamed this task from Separate sun lamp size as angle to Separate sun lamp size as angular diameter.
Brecht Van Lommel (brecht) raised the priority of this task from to Low.
Brecht Van Lommel (brecht) updated the task description.
Brecht Van Lommel (brecht) added projects: Good First Issue, Cycles, User Interface.
Brecht Van Lommel (brecht) edited a custom field.
Brecht Van Lommel (brecht) edited projects, added Render Pipeline; removed User Interface.
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Samarth Mediratta (samarthmed) claimed this task.Jan 3 2014, 8:19 PM
Samarth Mediratta (samarthmed) removed Samarth Mediratta (samarthmed) as the assignee of this task.Jan 3 2014, 8:22 PM
Samarth Mediratta (samarthmed) added a subscriber: Samarth Mediratta (samarthmed).
Samarth Mediratta (samarthmed) claimed this task.Jan 4 2014, 11:31 AM
ming liu (lunitari) added a subscriber: ming liu (lunitari).Jan 10 2014, 8:37 AM
Samarth Mediratta (samarthmed) added a comment.Jan 14 2014, 7:05 PM
Hi ,
So I walked around the intern code (sunsky.c) and found that their is a sun_size property in it. I understand that from the current UI , I am able to define the sun size property as float which as per you is the distance in meters. I get the concept of angular diameter that needs to be implemented here but could you please give me a starting point ? or point me to a resource that will help me figure things out on my own ?
I am new to development in blender and this is my first task.
Thanks
Brecht Van Lommel (brecht) added a comment.Jan 14 2014, 8:18 PM
I was actually thinking of the "Soft Size" property for Blender Internal shadows and the Size property for Cycles, although getting the sunsky setting to match would be good too.
In Cycles the code to change is in intern/cycles/render/light.cpp, LightManager::device_update_points, the LIGHT_DISTANT case. The radius there now is the radius of a disk pointed towards the origin, placed 1 unit away from the origin. So you need to figure out the math to convert that to an angle.
For Blender Internal this code actually seems quite broken, if you look in ray_shadow in rayshade.c, the LA_SUN case, then there's a comment about this not working correct. But you'd want to do the same kind of thing as Cycles, sample a disk with some radius, and you compute that radius from the user specified angle.
Anyway, this probably ends up being a relatively simple change but you need to be familiar with the math for it.
Samarth Mediratta (samarthmed) added a comment.Jan 18 2014, 8:29 PM
The formula was relatively easy if one knows their trigonometry. This indeed was a quick hack. Just needed to be pointed to the right file.
I have created a differential which has sun_size property set as sun's actual diameter in meters.
I understand the scenario that you're trying to apply in the la_sun case but the block also match the hemi lamp case. Do you really want me to sample a disk with the radius of the sun again ?
Also could you walk me through these variables so that I have a better understanding of implementing this in ray shade .
lampco[0]= shi->co[0] - R.maxdist*lar->vec[0];
		lampco[1]= shi->co[1] - R.maxdist*lar->vec[1];
		lampco[2]= shi->co[2] - R.maxdist*lar->vec[2];
And what exactly is lar ? LampRen doesn't really help.
Brecht Van Lommel (brecht) added a comment.Jan 19 2014, 3:59 PM
LampRen is the data structure for Lamps in blender internal, many data structures there have a Ren postfix to indicate they are renderer data structures.
ShadeInput describes the current shading point, ShadeInput.co is the location of the current shading point. LampRen.vec is the normalized direction vector of the lamp. R.maxdist actually should not be used here at all, not sure why it was ever done. It's the diameter of the scene bounding box I think. But really it should be taken into account at all.
What it has to do here is indeed sample a disk, just like Cycles.
I'm not sure what exactly you did in D229, the purpose of this change isn't really to hardcode the sun diameter. The point is to let users specify the sun size as an angle. The diameter of the sun in our solar system doesn't really come into it directly, just the angular diameter as seen from the earth should be enough.
Samarth Mediratta (samarthmed) added a comment.Jan 19 2014, 6:47 PM
Alright .. that's okay. I understand what I implemented was different from what you expected.
My only point is, to do this, you have to take into account the sun's diameter too. Consider this :
As per the wikipedia page that you mentioned, the user now specifies the angle 'delta'. Now to calculate the radius 'D' , we have to take into account the sun's diameter 'd'.
When the user inputs the angle 'delta', we can calculate 'D' only if we take the sun's diameter 'd' as a constant.
I am updating the differential again for you to see. Please see if that suits what you had in mind.
Once you approve of it, i'll try changing the code for rayshade.c
Thanks
Brecht Van Lommel (brecht) added a comment.Jan 20 2014, 1:52 PM
You don't need the distance to the sun or the diameter of the sun, the angle 'delta' is enough. The distance to the sun D = ∞, as the Cycles world background is assumed to be infinitely far away. For sampling you can understand of the code as setting D = 1, it doesn't really matter which distance you assume because you only need to sample a direction vector. There's this comment in the code, not sure if clears things up but it's the math I used:
/* a distant light is infinitely far away, but equivalent to a disk
 * shaped light exactly 1 unit away from the current shading point.
 *     radius              t^2/cos(theta)
 *  <---------->           t = sqrt(1^2 + tan(theta)^2)
 *       tan(th)           area = radius*radius*pi
 *        \    |           (1 + tan(theta)^2)/cos(theta)
 *         \   |           (1 + tan(acos(cos(theta)))^2)/cos(theta)
 *       t  \th| 1         simplifies to
 *           \-|           1/(cos(theta)^3)
 *            \|           magic!
 *             P
Anyway, looking at the code, I think the angular diameter is almost there anyway. I think the float angle in light.cpp and the theta in the above comment are half the angular diameter. So the code might just need to be:
float angle = light->size/2.0f;
float radius = tanf(angle);
Samarth Mediratta (samarthmed) added a comment.Jan 20 2014, 8:01 PM
The figure clears things out for sure. I think i'll have to read through the code more to understand the hardcore set of trignometric identities you had to use.
I have no understanding as to why you're choosing "the disk shape light exactly 1 unit away from the current shading point."
The distance does matter as it helps me to calculate the precise value of the radius.
But then again, choosing that distance as a constant (1), gives me the exact value of radius (tan(theta)) rather than tanf(theta) * the distance from the current shading point "P".
Anyway, thats just my trignometry talking. It'll be great if you point me to a resource that tells me more about cycles and light rendering in blender so that I understand the code more. Sounds exciting :)
You're right ... the float angle would be half the angular diameter. The only thing is that the math library in c++ calculates trignometric values only if the angle is passed as radians not degrees. So we need to do the necessary conversion before calculating the radius.
radians = (PI * angle / 180 ).
Here's the differential for it.
Thanks
Kévin Dietrich (kevindietrich) edited this Maniphest Task.May 1 2014, 4:23 PM
Bastien Montagne (mont29) added a project: BF Blender.May 20 2014, 4:36 PM
Aaron Carlisle (Blendify) added a subscriber: Aaron Carlisle (Blendify).Dec 16 2015, 9:55 PM
Can this be closed?
Brecht Van Lommel (brecht) moved this task from Backlog to UI on the Cycles board.Feb 21 2016, 2:58 PM
Campbell Barton (campbellbarton) removed Samarth Mediratta (samarthmed) as the assignee of this task.Mar 3 2017, 3:09 PM
Robert Fornof (amdbcg) added a subscriber: Robert Fornof (amdbcg).Mar 15 2017, 2:21 AM
  1. I will work from Samarth Mediratta's diff , and modify as needed.
  2. I will create a demo video when it is ready for review.
  3. I will hand this back if I cannot complete 1. or 2. by April.
Robert Fornof (amdbcg) added a comment.Mar 15 2017, 3:15 AM
https://developer.blender.org/D229
intern/cycles/app/cycles_xml.cpp
/* Generic */
 	xml_read_float(&light->size, node, "size");
+	xml_read_float(&light->sun_angle, node, "sun_angle");
 	xml_read_float3(&light->dir, node, "dir");
 	xml_read_float3(&light->co, node, "P");
 	light->co = transform_point(&state.tfm, light->co);
I cannot find any of that block in :
blender-build/blender/intern/cycles/app/cycles_xml.cpp Did it move or get re-done?
Mayur Odedara (maxyodedara5) added a subscriber: Mayur Odedara (maxyodedara5).Feb 1 2018, 6:01 AM
Rachit Jain (j-rachit) claimed this task.Dec 24 2018, 6:59 PM
Rachit Jain (j-rachit) added a subscriber: Rachit Jain (j-rachit).
Since it currently seems that no one is working on this, I will try to pick it up. A lot has changed in the code since the last patch was submitted so:
I will use Samarth Mediratta's diff as a starting point and write the code wherever it lives now. I'll try to finish this over the next 10 days, and will hand this back if I am unable.
Rachit Jain (j-rachit) added a comment.Jan 4 2019, 6:29 AM
Just a follow-up, I'm still working on this. I've managed to get to the point where Samarth Mediratta reached with their diff, and also managed to make the property show up in the UI. I'm looking into how to affect the size variable right now.
Tim Stullich (tstullich) added a subscriber: Tim Stullich (tstullich).Mar 11 2019, 7:33 PM
Tim Stullich (tstullich) added a comment.Mar 20 2019, 11:45 AM
@Rachit Jain (j-rachit) are you still working on this? The last comment you made was almost two months ago. If you are not working on this could you let me know and I'd be happy to take over from where you left off?
Tim Stullich (tstullich) added a comment.Mar 21 2019, 6:44 PM
@Brecht Van Lommel (brecht) I was able to work on implementing some backwards compatibility logic in version_update.py and now I need to work on integrating the above changes into Eevee, as you had mentioned. Where would I start to look into making changes for Eevee?
Brecht Van Lommel (brecht) added a comment.Mar 22 2019, 5:28 PM
@Tim Stullich (tstullich), search for SUN in source/blender/draw/engines/eevee.
Tim Stullich (tstullich) added a comment.Apr 26 2019, 1:36 PM
Sorry I have been absent from this for a while, but I am now picking things back up again. I was able to find this snippet of code in source/blender/draw/engines/eevee/shaders/lights_lib.glsl line 283:
float radius = ld.l_radius;
radius /= (ld.l_type == SUN) ? 1.0 : l_vector.w;
vec3 L = (ld.l_type == SUN) ? -ld.l_forward : (l_vector.xyz / l_vector.w);
return ltc_evaluate_disk_simple(radius, dot(N, L));
Should I be making a change there in order to integrate the sun angle changes? I am also curious where to make UI changes for EEVEE, since the sun angle needs to be adjustable in the UI. Could you point me to where those files are because I can't seem to find them?
Tim Stullich (tstullich) added a revision: D4800: Sun angle to angular diameter.May 5 2019, 3:12 PM
George Vogiatzis (Gvgeo) mentioned this in T63009: Quick Hacks cleanup.May 6 2019, 8:13 AM
Tim Stullich (tstullich) added a revision: D4819: Sun angle to angular diameter.May 7 2019, 4:29 PM
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved.May 15 2019, 4:25 PM
