Windows 7 64 bits
Nvidia Geforce Gtx 580
Broken: 2.70 RC1 19f7f9a
Also present on: 2.70 RC1 571f184
There's this new feature where you can click and drag several vertical sliders so that you can synchronize edit their values.
Currently in the 3D view, properties shelf, if you drag the "dimensions" values the "Y" slider seems to be out of sync with the others, either not working or having a different value
Select default cube
Open Properties shelf (N)
In "Transform>Dimensions" parameter click on X and drag down till over Z
Drag side ways to change value
Dimensions should stay in sync but Y value doesn't move
Also right clicking to cancel leaves the X value at 1.930 instead on original value
(other axis combinations also produce strange behavior, sometimes setting size to 0)
