Maniphest T39061
Regression: On full scene copy, linked models unparented from proxies
Closed, Duplicate
None
Zauber Paracelsus (zauberexonar)
Mar 9 2014, 2:12 AM
  • BF Blender
64bit Linux Mint 16
Linux Kernel 3.11.0
nVidia GTX 650 Ti, driver 319.32
Broken: 2.70 Release Candidate 1
Worked: 2.69.0 r60991
When you import a model into a scene from File->Link, you then "Proxy" the model to an armature so that you can control it. However, if you create a full copy of the current scene, then all proxied models get unparented from their proxies. Simply re-parenting does not work, as they get offset. The workaround is to go into pose mode with the proxy, select all bones, CTRL-C to copy the pose, go into Object mode and delete the proxy, then select the linked model and create a new proxy, and then in pose mode press CTRL-V to paste in the old pose. Needless to say, this is unnecessarily tedious.
  1. Import a model (as a group, I'm assuming) via File->Link
  2. Create a proxy for the model from its associated armature
  3. At the Scene selector at the top of the window, press the + button and select "Full Copy"
  4. The armature has been disassociated from its proxy.
Zauber Paracelsus (zauberexonar) created this task.Mar 9 2014, 2:12 AM
Zauber Paracelsus (zauberexonar) raised the priority of this task from to 90.
Zauber Paracelsus (zauberexonar) updated the task description.
Zauber Paracelsus (zauberexonar) added a project: BF Blender.
Zauber Paracelsus (zauberexonar) edited a custom field.
Zauber Paracelsus (zauberexonar) added a subscriber: Zauber Paracelsus (zauberexonar).
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Duplicate.Mar 11 2014, 7:50 PM
✘ Merged into T39033.
