Maniphest T39225
Ortho Perspective mode bug
Closed, Duplicate
None
Ricky J (rickyblender)
Mar 17 2014, 1:48 PM
  • BF Blender
Bastien Montagne (mont29)
OS: window 8.1
Video : HD8670 D
Blender Version 2525fc9 RC2
i have already set auto perspective mode in user preference and save these as default
and if i open 2.7 and do a file it seems to work fine
but if i open and old file made with 2.9 it does not seems to work properly
when i go into edit mode then back into object mode it goes from ortho to perspective mode !
i cannot upload sample file !
but any old 2.69 seems to have this bug on my OS
how do you drag and drop a file here ?
is it from explorer on win to this window ?
thanks
happy bl
Ricky J (rickyblender) created this task.Mar 17 2014, 1:48 PM
Ricky J (rickyblender) raised the priority of this task from to 90.
Ricky J (rickyblender) updated the task description.
Ricky J (rickyblender) edited a custom field.
Ricky J (rickyblender) added a subscriber: Ricky J (rickyblender).
Ricky J (rickyblender) added a comment.Mar 17 2014, 10:47 PM
I redid some tests
and found that if I change the auto perspective and save start up with Ctrl-u
it is refusing to save it
so when I re open 2.7 auto perspective is always activated !
thanks
Bastien Montagne (mont29) added a project: BF Blender.Mar 18 2014, 3:46 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
I can’t reproduce any of the reported issues here… Pleas upload a file that fails in 2.70 (yes, drag&drop works)…
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Mar 18 2014, 3:46 PM
Ricky J (rickyblender) added a comment.Mar 20 2014, 1:47 PM
sorry still have to learn how to drag and drop files here!
in any case this is dong this with all 2.69 files
I tried to change the auto perspective and save it with Ctrl-U then close
and re open and when I try to open 2.69 files it is still in auto perspective mode
this is the only SVN doing this
I will try to install 2.7 today and see if it does the same thing
thanks
Ricky J (rickyblender) added a comment.Mar 20 2014, 2:04 PM
just installed 2.7 on my PC
this is blender org official version
and it is doing the same thing
I cannot change the Var auto perspective
each time I open up a 2.69 file auto perspective is always on
I tried to change it then save it with Ctrl-u
the next time I re open a 2.69 file auto perspective is always set
each time I do a rotate in viewport it goes into perspective mode!
let me know what else I can try to correct that ?
thanks
Ricky J (rickyblender) added a comment.Mar 20 2014, 2:34 PM
I just got the latest buildbot version aee3018
it is basically having the same problem now!
if I open 2.7 and works as 2.7
I can see that the auto perspective is set
but it does not work it is like it is not being applied
and works normally !
I can rotate in viewport and it stays in ortho mode
if I open a 2.69 file then auto perspective is set and as soon as I rotate in viewport it goes into perspective mode !
strange problem
thanks
Ricky J (rickyblender) added a comment.Mar 20 2014, 2:42 PM
just saw something else here
if I open 2.69 file
as soon as I rotate it goes into perspective mode
if I manually reset auto perspective and save file under 2.7
then when I re open the same file
it works normally even if auto perspective is set
I can rotate and it does not go into perspective mode !
very strange
thanks
Bastien Montagne (mont29) added a comment.Mar 28 2014, 6:55 PM
Will merge into another report that looks very similar…
Bastien Montagne (mont29) changed the task status from Unknown Status to Duplicate.Mar 28 2014, 6:55 PM
✘ Merged into T39397.
