Maniphest T39320
zoom lags using linux (gentoo)
Closed, Archived
Bastien Montagne (mont29)
CRAIG COLEMAN (cwc1885)
Mar 21 2014, 12:37 PM
  • BF Blender
Thomas Dinges (dingto)
Broken: (example: 2.69.7 4b206af, see splash screen)
Related Objects
CRAIG COLEMAN (cwc1885) created this task.Mar 21 2014, 12:37 PM
CRAIG COLEMAN (cwc1885) raised the priority of this task from to 90.
CRAIG COLEMAN (cwc1885) updated the task description.
CRAIG COLEMAN (cwc1885) added a project: BF Blender.
CRAIG COLEMAN (cwc1885) edited a custom field.
CRAIG COLEMAN (cwc1885) added a subscriber: CRAIG COLEMAN (cwc1885).
CRAIG COLEMAN (cwc1885) added a comment.Mar 21 2014, 12:53 PM
I'm running Blender as a binary and when I zoom in or out on an object it has a lot of lag. The zoom works using the roller ball of the mouse. 4 gigs of ram. I'm using the binary because the install does not work.
I use Blender on a Mac 1 gig or ram running Lion and using Windows 7 and all is good.
Any ideas?
I'm running xf86-video-nouveau with 1 1 gig nvidia video card
uname -a Linux azzerare 3.12.13-gentoo #1 SMP Sat Mar 8 21:17:41 PST 2014 x86_64 AMD Athlon(tm) 64 Processor 3400+ AuthenticAMD GNU/Linux
Roller ball scrolls very slow I'm running Blender using Gentoo Linux -
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Mar 21 2014, 12:53 PM
bigbadbugreport
Empty report, closing!
Bastien Montagne (mont29) changed the task status from Archived to Unknown Status.Mar 21 2014, 12:57 PM
Uh… you were saved by the gong!
More than likely some issue with your driver, you may try to disable VBO or other graphic-related settings in user preferences -> System tab…
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Mar 21 2014, 12:59 PM
Btw, I assume you tried with Blender 2.70?
Oh, and you can also try to run Blender with the softwaregl script featured with official release…
Bastien Montagne (mont29) added a comment.Mar 21 2014, 1:12 PM
◀ Merged tasks: T39321.
Thomas Dinges (dingto) changed the task status from Unknown Status to Archived.Mar 25 2014, 10:04 AM
Thomas Dinges (dingto) added a subscriber: Thomas Dinges (dingto).
Use the proprietary nvidia driver instead of the nouveau one, this is probably the issue.
Blender heavily relies on a proper OpenGL support by the GPU/GPU driver, if that is malfunctioning, Blender will not work properly. Not much we can do here.
