Maniphest T39666
Bsurfaces addon bug: 'Add surface' crashes Blender under specific workflow.
Closed, Duplicate
Eclectiel L (eclectiel)
Chris Lee (infin8eye)
Apr 9 2014, 9:54 PM
  • Add-ons (Community)
Windows 7
Intel Core2 Extreme 3GHz
8GB RAM
NVIDIA GeForce 8800 GTS 512
Broken: 2.70
Bsurfaces addon crash bug:
'Add surface' crashes Blender under specific workflow. Caused by modifier data existing on a mesh (even if applied), before duplicating edge loops, separating and converting edges to curves, setting to bezier and applying 'add surface'.
Enable the Bsurfaces addon.
Create a cube, subdivide a few times, remove half, add a mirror modifier, and a subdivision surface modifier.
Select three edge loops, duplicated them (shift D), then separated them (P).
Hide, delete or move the original cube to another layer.
Convert the object with edges to curves
Set the curves to bezier using the Tool Shelf, curve tools
Add a plane, shift select it and then apply bsurfaces 'add surface'.
This crashed Blender every time.
I tried a few things including applying the modifiers before separating the edges but it always crashed. The only way it would work was if there was no modifier on the subdivided cube before I separated the edges. Then it would work as desired. I didn't test those two modifiers individually, or any other modifiers.
Plus if I saved the file just before I crashed it and apply 'add surface' again I start getting error message after error message. Please try this to view errors.
Chris Lee (infin8eye) created this task.Apr 9 2014, 9:54 PM
Chris Lee (infin8eye) raised the priority of this task from to 90.
Chris Lee (infin8eye) updated the task description.
Chris Lee (infin8eye) added projects: BF Blender, Add-ons (Community).
Chris Lee (infin8eye) edited a custom field.
Chris Lee (infin8eye) added a subscriber: Chris Lee (infin8eye).
Bastien Montagne (mont29) assigned this task to Eclectiel L (eclectiel).Apr 9 2014, 10:22 PM
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
Bastien Montagne (mont29) removed a project: BF Blender.
Chris Lee (infin8eye) added a comment.Jun 29 2014, 1:33 PM
mont29 assigned this to eclectiel, but I was told he is no longer active.
Is there anyone else willing to have a look at Bsurfaces?
Brendon Murphy (meta-androcto) closed this task as a duplicate of T39664: Bsurfaces Broken: Reorder splines, local view bug, misc errors..Aug 29 2015, 12:25 AM
