Maniphest T39828
Incorrect render layer visibility display for animated render layers
Closed, Resolved
Bastien Montagne (mont29)
Willi (willi)
Apr 21 2014, 2:43 PM
  • Animation & Rigging
  • BF Blender
Brecht Van Lommel (brecht)
Sergey Sharybin (sergey)
Willi (willi)
Win7/64, AMD HD 6850
since 2.57b
When navigating forward from a key frame for visibility of render layers to another key frame, the display does not match the actual values:
Actually, only layer 2 is visible.
  1. Open attached file: At frame 0, only render layer 1 is visible. At frame 1, only render layer 2 is visible.
  2. If you navigate from frame 0 to frame 1, the display (as shown in screenshot) incorrectly indicates both render layers are visible, whereas, when navigating from frame 2 to frame 1, display is correct.
Revisions and Commits
rB Blender
rBAC Blender Add-ons Contrib
Willi (willi) created this task.Apr 21 2014, 2:43 PM
Willi (willi) raised the priority of this task from to 90.
Willi (willi) updated the task description.
Willi (willi) added projects: BF Blender, User Interface.
Willi (willi) edited a custom field.
Willi (willi) added a subscriber: Willi (willi).
Bastien Montagne (mont29) added subscribers: Brecht Van Lommel (brecht), Campbell Barton (campbellbarton), Sergey Sharybin (sergey), Bastien Montagne (mont29).Apr 21 2014, 8:38 PM
Iirc, this should not be animatable? Brecht, Campbell, Sergey, can you confirm?
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Apr 21 2014, 8:38 PM
Sergey Sharybin (sergey) added a comment.Apr 21 2014, 8:43 PM
From my understanding the things they shouldn't be animatable. But i might be wrong.
Brecht Van Lommel (brecht) edited projects, added Animation & Rigging; removed User Interface.Apr 22 2014, 12:24 AM
Brecht Van Lommel (brecht) added a comment.Apr 22 2014, 12:30 AM
We disabled animation of scene layers because it gave dependency graph issues I think. This render layer value should not suffer from that particular problem.
I think the problem here is the way this RNA property interacts with the animation system. Because it's not allowed to have zero layers enabled, the f-curve that disables the first layer will be ignored when going from frame 0 to 1. That's a tricky issue as well though.
Sergey Sharybin (sergey) added a comment.Apr 22 2014, 8:04 AM
@Brecht Van Lommel (brecht), it doesn't seem render engine supports changes in render layers visibility. Here's a sample file which is free from the mentioned bug in animation but which fails to render animation{F85610}.
AFAIR, this bits are copied into Render and not being updated. We could support this, but isn't it a TODO and meanwhile marking layers as non-animatable is ok-ish thing?
Willi (willi) added a comment.Apr 22 2014, 11:46 AM
I see. I'll keep layer 20 visible all the time. Should be a temporary workaround. Not essential for me anyway, so I'll do it differently if you decide to drop animatability of render layers.
Thanks.
Brecht Van Lommel (brecht) added a comment.Apr 22 2014, 1:23 PM
I'm OK with this being marked non-animatable for now.
Bastien Montagne (mont29) claimed this task.Apr 23 2014, 4:23 PM
Bastien Montagne (mont29) edited this Maniphest Task.Apr 23 2014, 4:23 PM
Bastien Montagne (mont29) changed the task status from Unknown Status to Resolved.Apr 23 2014, 4:23 PM
Closed by commit rB14ab812da55a.
Bastien Montagne (mont29) edited this Maniphest Task.May 12 2014, 4:49 PM
