Maniphest T39963
OBS causes blender to crash on closure ,
Closed, Archived
Aaron Carlisle (Blendify)
Jacob Merrill (blueprintrandom)
Apr 30 2014, 8:38 AM
  • Game Engine
Bastien Montagne (mont29)
Mitchell Stokes (moguri)
solarlune
windows 7 - MSI afterburner 210
Broken: (2.7a)
using "game capture" causes belnder to crash on close
Run blender game engine, with game capture, on OBS, close blender
No .blend required,
Related Objects
StatusSubtypeAssignedTask
ArchivedAaron Carlisle (Blendify)
ArchivedMitchell Stokes (moguri)
Jacob Merrill (blueprintrandom) created this task.Apr 30 2014, 8:38 AM
Jacob Merrill (blueprintrandom) raised the priority of this task from to 90.
Jacob Merrill (blueprintrandom) updated the task description.
Jacob Merrill (blueprintrandom) added a project: Game Engine.
Jacob Merrill (blueprintrandom) edited a custom field.
Jacob Merrill (blueprintrandom) added a subscriber: Jacob Merrill (blueprintrandom).
Jacob Merrill (blueprintrandom) edited this Maniphest Task.Apr 30 2014, 8:38 AM
Mitchell Stokes (moguri) added a subscriber: Mitchell Stokes (moguri).Apr 30 2014, 9:09 AM
Is this a blender problem or an OBS problem?
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.May 1 2014, 4:42 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
solarlune added a subscriber: solarlune.May 8 2014, 7:41 AM
I'm able to confirm the bug (if I understand it correctly), which is:
If you open Blender, run the game engine, then use OBS to preview or capture the recording, it will be of the BGE (correct). When you close the BGE and then exit Blender, Blender will crash on exit (incorrect).
I'm using Windows 7 64-bit with an AMD Radeon HD 7700 graphics card. My Blender version is a Buildbot version from 5/4/2014 (May 4th).
Being that this is a crash on exit, it's not very critical since recording video should be unaffected, and Blender's quitting anyway, so it's not like your data should be lost. I'm not sure if it's a OBS issue or a Blender issue (i.e. OBS might be doing something to make Blender crash, or maybe Blender isn't handling something correctly). If I had to guess, it might be something to do with OBS, since Blender's normal otherwise; even Window capture works fine. Just Game capture makes Blender crash, so I'm not certain where the issue lies exactly.
Mitchell Stokes (moguri) lowered the priority of this task from 30 to Low.May 13 2014, 3:45 AM
I'm changing this to low priority as it probably won't get fixed anytime soon. It might be better to submit a bug to OBS. If they determine that a certain Blender/BGE feature/OpenGL call is causing problems, then maybe we can look at it. Until then, I'll just assume it's an OBS problem.
Aaron Carlisle (Blendify) changed the task status from Unknown Status to Unknown Status.Jun 29 2019, 2:15 AM
Aaron Carlisle (Blendify) claimed this task.
Aaron Carlisle (Blendify) added a subscriber: Aaron Carlisle (Blendify).
This task is being closed because the BGE has been removed in Blender 2.8.
