Maniphest T40098
Very specific set of circumstances causes crash (regarding compositing, file output node, Save Buffers setting, and multiple scenes)
Closed, Duplicate
None
Matt Hurley (hurleyman77)
May 8 2014, 8:38 PM
  • BF Blender
Lukas Tönne (lukastoenne)
Willi (willi)
Win7 Ultimate 64-bit
Two GeForce 650 (non SLI)
Phenom II x6
16GB RAM
All latest drivers as of 8 May 2014
Broken: 2.70 (the main release downloaded from Blender.org)
Blender crashes when all of this very specific set of circumstances is true:
There are more than 1 scene in the blend file,
and
One scene is set up to render any render layer from another scene in the file,
and
The scene doing the rendering is using a file output node,
and
The scene being rendered has "Save Buffers" turned ON in the render settings.
Open the attached blend fail and press F12 while in the scene called "rendering."
To prevent the crash, do ANY ONE (or all) of the following:
  • Remove the file output node from the scene called "rendering"
  • Remove the other scene from the compositing setup in "rendering"
  • Render the other scene from the compositor by clicking the camera button on its render layers node
  • Uncheck "Save Buffers" in the render settings of the other scene
This occurs with both the Blender Internal renderer and Cycles, as well with both CPU and GPU computation in the Cycles renderer.
Matt Hurley (hurleyman77) created this task.May 8 2014, 8:38 PM
Matt Hurley (hurleyman77) raised the priority of this task from to 90.
Matt Hurley (hurleyman77) updated the task description.
Matt Hurley (hurleyman77) added a project: BF Blender.
Matt Hurley (hurleyman77) edited a custom field.
Matt Hurley (hurleyman77) added a subscriber: Matt Hurley (hurleyman77).
Willi (willi) added a subscriber: Willi (willi).May 8 2014, 10:34 PM
Maybe related: T39985 (fixed recently). Give the latest build a try just to see if it's already fixed: http://builder.blender.org/download/
Lukas Tönne (lukastoenne) changed the task status from Unknown Status to Duplicate.May 9 2014, 9:54 AM
✘ Merged into T39985.
Lukas Tönne (lukastoenne) added a subscriber: Lukas Tönne (lukastoenne).May 9 2014, 9:55 AM
This is the exact same case as in in T39985, and works fine with current master. Please leave a comment if you still find problems with a recent version.
Matt Hurley (hurleyman77) added a comment.May 9 2014, 10:52 PM
Nope, looks like it's fixed. I guess I should have checked the latest build :-/ Thanks.
