OSX 10.9.5, GTX 660ti
Broken: 2.72 RC
Worked: pretty sure this is broken forever, i remember seeing weird behavior here before
Assigning object B as parent to an object A via the parent field in object relations panel in properties editor behaves differently depending on if object A has been a child before or not. For a user it is totally unclear what happens.
Open the attached file
Use the eyedropper tool or the text field to assign the object "parent" as parent to "ex-child" via the relations panel on the right side of the screen. The object stays in place.
Do the same with the object "new_child" and see how it uses the scale factors of the parent.
The only difference between the 2 objects is that i had parented "ex_child" to "parent" before through ctrl+p and cleared the parent after that by pressing the X in the parent selection field in the relations panel.
