Hey guys,
I wrote you a few weeks before regarding the incorrect (but intended) behaviour of the viewport switch.
In Maya you can hit the spacebar (Quadview), hover above the desired, different view, hit spacebar again and the selected new view appears
as the main viewport.
This is a VERY useful behaviour and in my opinion there's absolutely NO reason to change it.
(It worked in Blender 2.7 ...)
So please bring this feature back. (since Maya still works this way) ... in the meantime (or if you don't want to bring back this urgent feature)
Please tell me, how I can select a viewport after hitting spacebar...
hovering above a new viewport and try to select it with Shift/Alt/Ctrl + Space doesn't work and using the numbers is quite a weird way...
Thanks a lot,
Martin
