Maniphest T42859
SmartUV wrong aspect ratio projection on non square images
Closed, Resolved
None
Riccardo Giovanetti (harvester)
Dec 9 2014, 9:09 PM
  • BF Blender
Mobile Intel Core i7 720QM (1.66GHz), Win7 Pro 64bit, 8GB RAM, NVIDIA GTS 360M with 1GB VRAM
Broken: Blender 2.72.3 64bit (Hash: 690345a) (blender-2.72-690345a-win64.zip) from b.b.o.
Worked: I don't know (tested back to 2.62 and I get the same behaviour)
SmartUV projection on a non square image stretches the UV islands proportional to the image's aspect ratio.
I am not sure if the SmartUV projection is intended to be used only with square images, in that case it works fine and shame on me. Sorry.
Anyway, here are the steps:
  • Open Blender
  • enable factory settings
  • split the screen to add the UV/Image Editor
  • in the Image Editor create a new non square image (eg. 1024 x 512)
  • select the default cube
  • assign and properly map (UV coord) the above image to the default material on the default cube
  • unwrap the cube with SmartUV Project
You should notice that instead of squares the UV islands are rectangles whose aspect ratio is apparently driven by the associated image's aspect ratio.
While in other UV modes there is a checkbox named Correct Aspect which helps when dealing with non square images, with SmartUV this option seems not to be available (or applicable?).
A similar bug report, perhaps related to the above, might be T39601.
Thanks
Revisions and Commits
rB Blender
Related Objects
Riccardo Giovanetti (harvester) created this task.Dec 9 2014, 9:09 PM
Riccardo Giovanetti (harvester) raised the priority of this task from to 90.
Riccardo Giovanetti (harvester) updated the task description.
Riccardo Giovanetti (harvester) added a project: BF Blender.
Riccardo Giovanetti (harvester) edited a custom field.
Riccardo Giovanetti (harvester) added a subscriber: Riccardo Giovanetti (harvester).
Antonis Ryakiotakis (psy-fi) changed the task status from Unknown Status to Resolved.Dec 11 2014, 7:46 PM
Antonis Ryakiotakis (psy-fi) added a commit: rBf1ddf99580bf: Fix T42859 smart UV unwrap does not support aspect correction..
Closed by commit rBf1ddf99580bf.
