Windows 8.1 x64
Intel Pentium E2180 @ 2.00GHz
Intel 82945G Express Chipset Family OpenGL 1.1
2gb ram
Broken: 2.73 x64 official release. Can't see splashcreen
Worked: 2.72b x64 official release.
Blender crashes immediately after opening it. I can see the Blender window for a fraction of a second and then it closes. Nothing happens after that, there is no error or crash window or anything. It just closes.
Just open it with a similar rig. However, I reported a similar error before, T39706, but it was disregarded as a fault of the unsupported Intel gpu. It turned out that I had problems with my user files, that was my fault and I fixed it deleting my user files. Nothing to do with the gpu. I thought now it could be the same, but after using other user files, and manually disabling addons, it still won't open. This is all I did:
Installing a clean copy of 2.73 x64. At this point there is no user folder at /users/admin/appdata/roaming/blender foundation/blender - Blender instantly closes
Downloading zipped versions of 2.73, both 32 and 64 bit - Both Blender(s) instantly close.
Manually copying user files from 2.72 folder to a new 2.73 folder - Blender instantly closes, but I could see the previous theme and layout configuration I had during that instant.
Disabling folders one at a time at /program files/blender foundation/blender/2.73/scripts to do some amateur debugging - Blender instantly closes, sometimes I can see some things dissapearing but that's it, it closes nonetheless.
Reinstalling the older 2.72b - It works perfectly.
Installing 2.73, 32 bit on another computer. Windows8 32 bit, 1gb of ram, Intel Atom N450, Intel GMA 3150 OpenGL 1.4 - It works perfectly
Hopefully it isn't GPU related
Since 2.72 works perfectly I don't think it is the GPU though I know you will drop support for OpenGL 1.1 in the future. In the meantime I will report it as bug. Thanks for your hard work.
