UVs get stretched on the mirrored side of the model if you slide a vertex / Edge(double tapping g).
(Sorry if this is a double post, couldn't find a newer one)
Revisions and Commits
| rB Blender | |||
| rB9dc9f84740d2 Fix T45458: Edge Slide Mirror doesn't preserve UVs | |||
| Status | Subtype | Assigned | Task | ||
| Resolved | None | T8209 Edge Slide doesn't work with X-Mirror edit | |||
| Resolved | None | T45458 Edge Slide with X Mirror doesn't preserve UVs |
Ok, i'm using the official 2.75 build and the edge slide, while correct uvs is on only corrects one side e.g. in this file i have made a simple cube with an edge on both sides, turned x mirror on and slided it up a bit. then turned on the correct uv's option and it properly corrected one side, but the other stayed stretched:
https://www.dropbox.com/s/hs2z6u8fjsjmena/Edgeslide_problem.blend?dl=0
it should have a texture applied, but maybe you'll need to apply one again^^
