Maniphest T45589
When activating and using Bsurfaces GPL Edition Add-on Ctrl+Z/ Undo stops working
Closed, Duplicate
Brendon Murphy (meta-androcto)
Ramon S. (Supamon)
Jul 28 2015, 1:01 PM
  • Add-ons (Community)
Eclectiel L (eclectiel)
Ramon S. (Supamon)
Sergey Sharybin (sergey)
Windows 8.1 64 bits
Broken: 2.75 c6b042b
When enabling BSurfaces and once it is used for once, Undo/ctrl+Z breaks. Once done that, even if the add-on is disabled it remains broken.
I have tried it loading factory settings and just doing the enabling and using of the Bsurfaces add-on and it reproduces every time and in other computers.
Please any help with this issue will be very much appreciated thus my workflow greatly depends on Bsurfaces and Undo.
Thanks in advance, you guys do an amazing work.
Related Objects
Mentioned Here
rBc6b042be9ef3: Accidentally marked as 'rc'
Ramon S. (Supamon) created this task.Jul 28 2015, 1:01 PM
Ramon S. (Supamon) raised the priority of this task from to 90.
Ramon S. (Supamon) updated the task description.
Ramon S. (Supamon) added a project: BF Blender.
Ramon S. (Supamon) edited a custom field.
Ramon S. (Supamon) added a subscriber: Ramon S. (Supamon).
Ramon S. (Supamon) added a comment.Jul 28 2015, 1:05 PM
Sorry, maybe i must have tagged it in Addons Bugs. It is my first bug report. Sorry
Sergey Sharybin (sergey) edited projects, added Add-ons (Community); removed BF Blender.Jul 28 2015, 2:54 PM
Sergey Sharybin (sergey) added subscribers: Sergey Sharybin (sergey), Eclectiel L (eclectiel).Jul 28 2015, 2:57 PM
I cant reproduce the issue actually. I've just enabled Bsurfaces addon from the default cube scene, moved cube couple of times and hit ctrl-z and it worked. I also don't see any keymap modifications happening in the addon source.
CC-in developer of the addon anyway.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.Jul 28 2015, 2:57 PM
Brendon Murphy (meta-androcto) added a subscriber: Brendon Murphy (meta-androcto).Jul 29 2015, 8:08 AM
hi, not sure if this relates to the addon or grease pencil.
there's no turn off global undo call in bsurfaces,
That said, I'm able to reproduce the error with & without bsurfaces use.
Ramon S. (Supamon) added a comment.Jul 29 2015, 9:24 AM
Maybe I have not explained myself correctly, it stops working once you have used bsurfaces, not only enabling it, it has to be used.
Brendon Murphy (meta-androcto) added a comment.EditedJul 29 2015, 10:10 AM
I was able to reproduce the error without using bsurfaces.
however in a new session unable to reproduce.
I did find some lines in bsurfaces using global undo,
they might be turning off global undo then not turning back on.
It's worth investigating further,
lines 3205 & 3204 in bsurfaces may be near the issue.
Brendon Murphy (meta-androcto) claimed this task.Jul 29 2015, 12:13 PM
Brendon Murphy (meta-androcto) triaged this task as 50 priority.
Brendon Murphy (meta-androcto) closed this task as a duplicate of T39664: Bsurfaces Broken: Reorder splines, local view bug, misc errors..Aug 29 2015, 12:25 AM
