Maniphest T46503
snap seems broken when scaling
Closed, Resolved
None
Roy Mathew (roym)
Oct 16 2015, 3:57 AM
  • BF Blender
nullpoint
Roy Mathew (roym)
Sylvio Sell (semmi)
Ubuntu 14.04 (Trusty) running on a Lenovo laptop T500.
Broken: (2.69)
Worked: N/A
When scaling the right object along the x-axis with snap turned on,
the snap doesn't snap to the object on the left.
Open the attached .blend file.
Select the object on the right.
Scale along the x-axis to the left
Notice that snap doesn't work.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
rB4aac73a86f00: Correct own error w/ snap-scale T46503
rB15364094d022: Fix snap-scale w/ axis constraint
rB23848a70de47: Correct own error w/ snap-scale T46503
rB62225057394b: Fix snap-scale w/ axis constraint
Mentioned Here
T39161: scaling in viewport doesn't work with snap to nearest vertex.
T500: Halo render
Roy Mathew (roym) created this task.Oct 16 2015, 3:57 AM
Roy Mathew (roym) raised the priority of this task from to 90.
Roy Mathew (roym) updated the task description.
Roy Mathew (roym) added a project: BF Blender.
Roy Mathew (roym) edited a custom field.
Roy Mathew (roym) added a subscriber: Roy Mathew (roym).
Roy Mathew (roym) added a comment.EditedOct 16 2015, 4:01 AM
forgot to add .blend file earlier.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved by committing rB2f35217849c8: Fix T46503: Snap scale fails using corner pivot.Oct 16 2015, 6:07 AM
Campbell Barton (campbellbarton) added a commit: rB2f35217849c8: Fix T46503: Snap scale fails using corner pivot.
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).EditedOct 16 2015, 6:09 AM
Thanks for the report, fixed in master, note that since 2.69 - a related bug (T39161) was fixed too, so worth using recent builds - https://builder.blender.org/download/
We may back-port this for 2.76a.
Roy Mathew (roym) added a comment.Oct 16 2015, 1:42 PM
Thankyou very much. I've also updated the SO thread to mention the fix.
nullpoint added a subscriber: nullpoint.Oct 18 2015, 2:41 PM
Snap tool still broken. No difference in daily builds
Campbell Barton (campbellbarton) added a comment.Oct 19 2015, 3:21 AM
@nullpoint, checked again with master and its working here.
perhaps @Roy Mathew (roym) can confirm if the fix is working.
Roy Mathew (roym) added a subscriber: Sylvio Sell (semmi).EditedOct 19 2015, 2:43 PM
The fix is working for me.
@nullpoint - I looked at your .blend file attached to the thread at http://blender.stackexchange.com/questions/39981/snap-to-edge-vertex-when-scaling . It's a large file and it's not clear what isn't working - can you reduce the problem to a small file with 2 objects.
nullpoint added a comment.EditedOct 19 2015, 3:36 PM
2.75 working
2.76 broken
Daily build still broken.
Thank you the care about.
Sylvio Sell (semmi) added a comment.Oct 19 2015, 3:57 PM
i realized this problem to (with 2.76),
but only if scaling around >3d-cursor< (and cursor is exactly on vertex-point),
if scaling around origin, problem did not occurs
nullpoint added a comment.EditedOct 19 2015, 4:02 PM
Im scaling around origins, as you can see on gif attachments.
(actually thats a median point because i try everything, but im work with origins mode, and every mode working in 2.75)
Do you need any information from my workmachine and operating system or etc, for easier problem identification?
Sylvio Sell (semmi) added a comment.Oct 19 2015, 5:08 PM
mhm, may its a bug ;) ... i only read this thread and tryed to reproduce ...
same behaivor here with 2.76
( reduced sample from stackexchange here:
Roy Mathew (roym) added a comment.Oct 19 2015, 5:16 PM
@Sylvio Sell (semmi) - you're right. I tried it with Campbell's fix: this .blend demonstrates that there still is a snap problem.
nullpoint added a comment.EditedOct 23 2015, 1:06 AM
I'm so excited :D : D A trying every daily build . I will shout if all right :)
Campbell Barton (campbellbarton) mentioned this in rB62225057394b: Fix snap-scale w/ axis constraint.Oct 23 2015, 3:35 AM
Campbell Barton (campbellbarton) added a comment.EditedOct 23 2015, 3:35 AM
Committed fix for snap_problem-1-reduced.blend rB62225057394b61c66cb7cb2ce1e9b8c62170c0d8.
Set axis alignment to Z while snapping and this works as expected.
@Sylvio Sell (semmi), best just report a new bug, if you notice a fix for one bug doesn't resolve an error in a related area.
nullpoint added a comment.EditedOct 23 2015, 11:58 AM
Hello!
blender-2.76-6222505-win64 daily build seems working Z and Y axis, there is a strange thing on X axis. See gif upper right corner , if snapping X axis.
daily276zy
Its will be good very soon. I feel it :)
Campbell Barton (campbellbarton) mentioned this in rB23848a70de47: Correct own error w/ snap-scale T46503.Oct 23 2015, 12:40 PM
Campbell Barton (campbellbarton) added a comment.Oct 23 2015, 12:41 PM
@nullpoint, corrected rB23848a70de47273496111e29c53d1d7b64c4c090
nullpoint added a comment.Oct 25 2015, 10:57 AM
Good news!
Latest build working awesome properly!!!
This team the best!
( i cant be able to use blender git currently, so i cant did the code change, what Campbell linked. :)  ( but i will learn)   )
Campbell Barton (campbellbarton) mentioned this in rB15364094d022: Fix snap-scale w/ axis constraint.Oct 29 2015, 11:40 AM
Campbell Barton (campbellbarton) mentioned this in rB4aac73a86f00: Correct own error w/ snap-scale T46503.
