Windows 10 x64 Pro
Radeon R9 380 4G
Broken: 2.76b
Worked: On AMD drivers from last year
I have already reported this bug in the past, but it was ignored because AMd drivers were not stable then.
Now it happens on certified stable driver release, and on blender stable release.
The problem is: If you use GPU compute on AMD GPU with Cycles, the sampling is broken and results in visible horizonral artifacts instead of normal noise.
I attach the simplified project here, just hit F12 to render again with AMD:
Here is also the errornous render result:
Please don't say again that you don't care, apparently a lot of people use their AMDs to render things and WONT want to downgrade drivers.
Thank you.
