Maniphest T48144
Multi windows performance drop
Closed, Archived
Bastien Montagne (mont29)
kevin deguisne (iscream)
Apr 14 2016, 10:44 AM
  • BF Blender
mangostaniko
Navigation in the 3D view is really slow when having multiple windows open, even when there is no 3D inside them
Perhaps there should be an optionnal "turbo mode" to only update inactive windows every X milliseconds, if it's not a bug
win7 x64 gtx 970 / 3 screen
blender 2.77a
kevin deguisne (iscream) created this task.Apr 14 2016, 10:44 AM
kevin deguisne (iscream) raised the priority of this task from to 90.
kevin deguisne (iscream) updated the task description.
kevin deguisne (iscream) added a project: BF Blender.
kevin deguisne (iscream) edited a custom field.
kevin deguisne (iscream) added a subscriber: kevin deguisne (iscream).
mangostaniko lowered the priority of this task from 90 to 30.Apr 15 2016, 1:44 AM
mangostaniko added a subscriber: mangostaniko.
What exactly do you mean by multiple windows? How many, at what resolution, what else is running in the background, does it get better if you close some of the windows?
Could you upload a .blend file to reproduce the issue?
kevin deguisne (iscream) added a comment.Apr 15 2016, 9:13 AM
I canno't share the scene but this is a screen shot of ma setup, 3 full HD sceen, one vertical, 3 windows, I instantly get almost 60 fps when I close the two side windows, other wise it seems to be lower than 10
mangostaniko added a comment.EditedApr 15 2016, 10:19 AM
So basically all i can guess is that it might just be too much to ask from your GPU.
At least it does not appear to be Blender specific.
kevin deguisne (iscream) added a comment.Apr 15 2016, 2:20 PM
Well, to me it's a bug ... when I minimize the two side windows, it's still slow and fast if I close them
Also there is no difference in CPU usage
mangostaniko added a comment.EditedApr 15 2016, 4:03 PM
Does this only happen with Blender?
I must admit i have no experience with multiple monitors maybe someone might have an idea.
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).Apr 22 2016, 7:52 PM
In any case, we cannot do anything here really, this is specific to your hardware and software setup, plus the scene you are working on! Yes, having three HD OpenGL contexts is much more heavy than one - would not expect a gtx970 to be a limit here, though.
Other points to check/try:
  • Does it happen with default startup blender (i.e. very light scene)?
  • Check if the bug is reproducible on another, similar computer (this horribly sounds like over-heating or so).
  • Give us your exact Blender, OS and GPU (including drivers) versions, as requested in the template!
  • Ensure both your OS and drivers are fully up-to-date.
  • Try the latest build from our buildbot.
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
  • Try to tweak OGL settings in UserPreferences, System tab (window.draw methods, multisampling...).
  • Try to tweak your GPU driver settings (e.g. try different values between 'performance' and 'quality' if you have such slider, etc.).
  • Attach as text file here the report generated by Help -> System Info (do not paste it directly in comment).
  • Try to place this dll next to your blender.exe (software OGL, will be slow, but will show whether this is a driver issue or not).
kevin deguisne (iscream) added a comment.EditedApr 29 2016, 10:35 AM
I don't think all those point are relevant.
My point is that blender seems to take some time to redraw all windows even when 2 of them are minimized
Other operation can be slow because, moving an object could affect an other object, a drived value in a node graph, change the curves in the graph editor etc...
But navigation only, should not, , it only affect the view where the mouse is. (except when camera is locked)
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Apr 29 2016, 11:57 AM
Seriously… You know Blender codebase that well?
Anyway, no point in keeping this open, if you do not want to do your share of the work. Tracking bug, especially that kind of config-specific ones (if multi-monitor/blender window was generally that slow, think we would have known since ages already, you are not the only user with three screens around), requires full cooperation from reporter, we cannot do anything otherwise (it’s hard enough to handle already).
kevin deguisne (iscream) added a comment.May 2 2016, 6:28 PM
sorry... I was wrong, removing all my ad-don solved the "bug", I still have to find wich one.
Thank you
