Maniphest T48202
Texture paint in the 3d View will crash, if you not check "Clamp Overlap" in the Bevel modifier
Closed, Resolved
None
Leroy (Leroy)
Apr 20 2016, 3:55 AM
  • BF Blender
Leroy (Leroy)
Samuel (ONNIU)
Sergey Sharybin (sergey)
YimingWu (NicksBest)
windows 7 64 bit sp1
Broken: 2.77a abf6f08
If you paint texture in the 3d view and don't check the "Clamp overlap" in the bevel modifier will make blender use cpu 100%, than crash your computer. it's happen by sometimes, especially paint on the edge area, if you check "Clamp overlap" will work fine, and the small width in the save range will work too.
I am glad I found out why, it's make me crash too, you can download the blend file to verification this , hope this can helpful, sorry for my poor English, very thanks.
Just open the .blend file, than paint in the 3d view.
Revisions and Commits
rB Blender
Related Objects
Leroy (Leroy) created this task.Apr 20 2016, 3:55 AM
Leroy (Leroy) raised the priority of this task from to 90.
Leroy (Leroy) updated the task description.
Leroy (Leroy) added a project: BF Blender.
Leroy (Leroy) edited a custom field.
Leroy (Leroy) added a subscriber: Leroy (Leroy).
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).Apr 20 2016, 4:04 AM
Can't redo this bug, did this ever work?
Where are you painting exactly when Blender hangs?
Leroy (Leroy) added a comment.Apr 20 2016, 4:47 AM
@Campbell Barton (campbellbarton) not ever, more happen on the edge area that bevel edge, check "Clamp overlap" will fine.
Leroy (Leroy) added a comment.Apr 20 2016, 4:57 AM
@Campbell Barton (campbellbarton) I'm confused, I ask my friend to test this, he is ok, not crash : (
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 30.Apr 20 2016, 7:19 AM
YimingWu (NicksBest) added a subscriber: YimingWu (NicksBest).Apr 20 2016, 5:06 PM
Hello leroy,
I personally *Veryfied* this bug, it do happen when dragging mouse repeatedly over those seam areas, the interface halted and caused cpu usage to rise to about 35%, and about five second later it resumed. Later I'll upload a gif describing this issue.
YimingWu (NicksBest) added a comment.EditedApr 20 2016, 5:12 PM
Here is a short demostration of the bug{F304534}
Leroy (Leroy) added a comment.Apr 21 2016, 3:13 AM
Hi @YimingWu (NicksBest) very thanks for verify this, it's make me crazy
Campbell Barton (campbellbarton) added a comment.Apr 25 2016, 8:07 AM
I can redo the slow-down @YimingWu (NicksBest) points out, but not the crash.
@Leroy (Leroy) - is Blender actually crashing? (exiting with some error), or does it just stop responding?
Leroy (Leroy) added a comment.EditedApr 25 2016, 9:18 AM
@Campbell Barton (campbellbarton) not actually crashing, no exiting or error tip, just stop responding, perhaps because my computer too low, the CPU will become very high, and than stop responding, but if I check "Clamp overlap", it's will be work fine. never happen that.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved by committing rB3ac2028df0c4: Fix T48202: Project paint hangs on UV's w/ sharp corners.Apr 25 2016, 2:18 PM
Campbell Barton (campbellbarton) added a commit: rB3ac2028df0c4: Fix T48202: Project paint hangs on UV's w/ sharp corners.
Campbell Barton (campbellbarton) merged a task: T48217: Texture Paint Crashing PC.Apr 25 2016, 2:20 PM
Campbell Barton (campbellbarton) added subscribers: Sergey Sharybin (sergey), Samuel (ONNIU).
