Maniphest T48297
Scalar Group Node Output is One Pixel Large
Confirmed, NormalKNOWN ISSUE
None
Sofus Rose (Darkfie9825)
Apr 28 2016, 7:07 AM
  • BF Blender
  • Compositing
  • VFX & Video
Bastien Montagne (mont29)
Jalen Jobes (RealJayJobes)
Jeroen Bakker (jbakker)
Philipp Oeser (lichtwerk)
Sergey Sharybin (sergey)
Tokens
"100" token, awarded by RealJayJobes.
uname -r: 4.3.0-1-amd64
Debian 8 testing (sid)
Broken: 2.77a (official tar'ed build from blender.org)
My compositing node system relies extensively on nodegroups, sometimes nested several layers deep. Sometimes, these nodegroups need to process not a bitmap, but simply an individual scalar value - which might be inputted using the RGB node, or the Value node. It's when outputting a scalar from a nodegroup that it breaks; the output value is a bitmap that is one pixel large.
I suspect that any person or studio interested in creating a nested node system for their own ease of use will run into this issue!
  1. Load compositing scene.
  2. Create 2 Math nodes. Put each in its own nodegroup.
  3. Let each nodegroup have one input and one output, passing through the Math node's first input within each group. In both cases set the Math node to Multiply, and the second input to 1.
  4. Pass in the value 1 for the first nodegroup, and let the output of nodegroup 1 become the input of nodegroup 2.
  5. Find any image, and plug it into the first input of a color Multiply node. In input 2, plug in the output of nodegroup 2.
  1. Notice as a single pixel in the image remains unchanged, as the rest of the image becomes black.
I attached screenshots to better illustrate the setup:
Sofus Rose (Darkfie9825) created this task.Apr 28 2016, 7:07 AM
Sofus Rose (Darkfie9825) raised the priority of this task from to 90.
Sofus Rose (Darkfie9825) updated the task description.
Sofus Rose (Darkfie9825) added projects: BF Blender, Compositing.
Sofus Rose (Darkfie9825) edited a custom field.
Sofus Rose (Darkfie9825) added a subscriber: Sofus Rose (Darkfie9825).
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Apr 29 2016, 12:28 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Huummm, seems to have been solved since 2.77a? I cannot confirm that with latest master here, please try the latest build from our buildbot. Otherwise, please attach a .blend, much simpler for us to reproduce and investigate.
Sofus Rose (Darkfie9825) added a comment.EditedApr 29 2016, 9:27 PM
Aha! It's a bug with the Buffer Groups option! Bug hunting is fun...
I'll provide a blend:
Turn off Buffer Groups and recomposite, and it'll work perfectly. Turn it back on, and there'll be a single pixel glaring at you!
I tested this with the latest (4AM) build as well; the bug persists.
Sergey Sharybin (sergey) raised the priority of this task from 30 to 50.May 3 2016, 3:19 PM
Sergey Sharybin (sergey) added a subscriber: Sergey Sharybin (sergey).
Sergey Sharybin (sergey) assigned this task to Jeroen Bakker (jbakker).May 3 2016, 3:24 PM
Sergey Sharybin (sergey) added a subscriber: Jeroen Bakker (jbakker).
@Jeroen Bakker (jbakker), there are two issues here:
  1. The one which is reported in this repot
  2. If you ungroup second group, then you'll have some nasty race conditions between group buffer read and write operations, causing wrong compo results.
First issue is probably not so hard, but second one i couldn't really fix today and wouldn't mind having some debuging from you ;)
Jeroen Bakker (jbakker) added a comment.May 4 2016, 10:13 PM
Issue seems likely to be caused by MathBaseOperation::determineResolution
it first checks if there are is a connection what can be marked as being important. This is done by determining the resolution with using a dummy preferred resolution of (0,0).
The Multiply node caches this resolution for next calls. and therefore also returns this. When 0,0 is returned it is set to 1,1 by WriteBufferOperation::determineResolution
When commenting out the code at MathBaseOperation::determineResolution the issue is solved, but it impacts the functionality of the node (determining the right output resolution). We need to see how we can really check what path determines the correct output resolution.
This part is also implemented by the MixBaseOperation. Could not find other nodes with this implementation.
We propose that we add a boolean to the NodeOperation::determineResolution method bool cache=true. In the MixBaseOperation and the MathBaseOperation we set cache to false. This way we get the answer we want without influencing the rest of the system. Also need to change the setResolution for this one.
@Sergey Sharybin (sergey), what do you think about this solution?
Sergey Sharybin (sergey) added a comment.May 4 2016, 10:29 PM
Not really fan of that. It's just some corner-case complication over the system which is already really unclear. Unless you can come up with really strict rule of how determineResolution() should behave, when to cache and when not i;m not really fan of such hacks.
Why can't we just change fallback resolution to (1, 1) ? Or if some nodes really don't need to cache resolution, overload their isResolutionSet()?
Also, be aware that resolution is is caching for a reason -- with a complex enough nodes setup it might take forever to calculate resolution, since this part of the code is actually an exponential complexity.
Chaitanya Subhedar (DoomScream) added a subscriber: Chaitanya Subhedar (DoomScream).Oct 9 2017, 5:25 AM
Chaitanya Subhedar (DoomScream) removed a subscriber: Chaitanya Subhedar (DoomScream).
Dalai Felinto (dfelinto) removed Jeroen Bakker (jbakker) as the assignee of this task.Dec 23 2019, 4:37 PM
Dalai Felinto (dfelinto) added a project: Tracker Curfew.
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".Jan 28 2020, 9:27 AM
Jeroen Bakker (jbakker) removed a project: Tracker Curfew.
Richard Antalik (ISS) added a project: VFX & Video.May 21 2020, 1:36 PM
Sergey Sharybin (sergey) moved this task from Backlog to Known Issues on the VFX & Video board.Jun 12 2020, 4:08 PM
Jalen Jobes (RealJayJobes) awarded a token.Nov 11 2021, 3:15 PM
Philipp Oeser (lichtwerk) added subscribers: Jalen Jobes (RealJayJobes), Philipp Oeser (lichtwerk).
Aaron Carlisle (Blendify) moved this task from Backlog to Known Issues on the Compositing board.Dec 5 2021, 6:58 PM
