Maniphest T48491
delete of NULL pointer is noop, so no need to check
Closed, Archived
Bastien Montagne (mont29)
Lawrence D'Oliveiro (ldo)
May 22 2016, 8:40 AM
  • BF Blender
In C++, it is unnecessary to check for non-NULL before invoking delete:
if (foo) delete foo;
can be more simply written as
delete foo;
(Ref: section 5.3.5 of the C++98 spec, paragraph 2.)
This patch just fixes some initial cases I came across; no doubt there are others waiting to be found.
Lawrence D'Oliveiro (ldo) created this task.May 22 2016, 8:40 AM
Lawrence D'Oliveiro (ldo) raised the priority of this task from to 90.
Lawrence D'Oliveiro (ldo) updated the task description.
Lawrence D'Oliveiro (ldo) added a project: BF Blender.
Lawrence D'Oliveiro (ldo) edited a custom field.
Lawrence D'Oliveiro (ldo) added a subscriber: Lawrence D'Oliveiro (ldo).
Sorry, I should have marked this as a patch, not a bug.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.May 22 2016, 6:51 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Thanks for the patch, be we for sure won’t touch to extern library's code - not until it’s a question of live or death for Blender! :P
Suggest you report the issue to carve team.
Lawrence D'Oliveiro (ldo) added a comment.May 23 2016, 2:50 AM
I see the header files refer to http://carve-csg.com/, which no longer exists.
So where is this “carve team” to be found?
