Windows 8.1 64 bit
nVidia GT 740
Broken: 2.77 (and all of which I have memory)
Worked: none (which I remember)
Left and Right Views are swapped: They show the opposite side.
When I set the reference images for a mesh, I always have to set the Left image onto the Right view and vice-versa.
Which is very confusing.
In this blend file, the left side is red and the right side is black (easily associatable to politics colors).
If you'll hit 3 (Right view), you'll see the Left side of the mesh.
If you'll hit Ctrl+3 (Left view), you'll see the Right side of the mesh.
Isn't this annoying a lot?
