Maniphest T48724
Error with nodewrangler add-on...
Closed, Duplicate
None
Brandon Hix (Acolyte)
Jun 23 2016, 11:31 PM
  • Add-ons (Community)
Vuk Gardašević (lijenstina)
Apologies if any of this is incorrect, or if this has already been reported. This is my first bug report.
Mac Pro
2.93 GHz Quad-Core Intel Xeon
18GB 1066 MHz DDR3 ECC
NVIDIA GeForce GTX 660 2048 MB
Broken: 2.77a abf6f08
After enabling the nodewrangler add-on I proceed to build a shader network. IE: A simple diffuse and glossy input into a mix shader then connected to the output node. When using the 'Shift+s' to switch the mix node to an add node I get the following error:
  File "/Applications/Blender/blender.app/Contents/Resources/2.77/scripts/addons/node_wrangler.py", line 1897, in execute
    force_update(context)
NameError: name 'force_update' is not defined
The same error can be generated whenever I try to use the 'Shift+S' to swap out one node for another.
Thanks,
Brandon Hix
Brandon Hix (Acolyte) created this task.Jun 23 2016, 11:31 PM
Brandon Hix (Acolyte) raised the priority of this task from to 90.
Brandon Hix (Acolyte) updated the task description.
Brandon Hix (Acolyte) added a project: Add-ons (Community).
Brandon Hix (Acolyte) edited a custom field.
Brandon Hix (Acolyte) added a subscriber: Brandon Hix (Acolyte).
Vuk Gardašević (lijenstina) added a subscriber: Vuk Gardašević (lijenstina).Jun 24 2016, 12:19 AM
This is same as task as T48094
There was some issue with the right version of node wrangler in 2.77a.
Replace the node_wrangler.py in your blender install with the one from the latest dev build or from here
Bastien Montagne (mont29) closed this task as a duplicate of T48094: Node Wrangler Force Update Traceback Error.Jun 24 2016, 2:51 PM
