Blender build 29.7.2016
Loops are defined:
Press W, Bridge edge loops
You can see that loops are not bridged accordingly
If I use loop tools add-on and press Bridge, I get this error:
| Brendon Murphy (meta-androcto) |
| soulfire (vejn) | |
| Jul 29 2016, 11:45 PM |
| Bart Crouch (crouch) |
| soulfire (vejn) |
Loops are defined:
hi, closing as resolved.
this is really a corner case. If you select opposing faces individually & use either built in or looptools to bridge edge loops or bridge or loft, this works.
simply you are trying to do too much. the error reported by looptools is what i would expect to see & fail here.
a side note, in this case also extrude would do the job in seconds.
