Maniphest T49779
Cycles Texture Bake with GPU freezes MacBook Pro (AMD Radeon R9 M370X)
Closed, DuplicateBUG
None
Symen (Symen)
Oct 18 2016, 12:40 PM
  • BF Blender
  • Cycles
Symen (Symen)
MacBook Pro / macOS Sierra 10.12 / AMD Radeon R9 M370X VRAM 2048 MB
Blender Version: 2.78 hash:6f92604
Compute Device: AMD Radeon R9 M370X / Cycles Render
Render and Preview are working fine but Bake is going to freeze the complete System.
Process bar keeps saying 0%, the computer is heating up and just a hard reset will work.
This problem also was happening on the OS X before Sierra.
create a simple scene in Blender Cycles Render:
Create a plane (ground), a plane (emission material) and a cube (UV unwrapped). Set the cube on the ground, position the light.
Create a new texture in image editor (512x512), name it TEST.
Create a diffuse material with texture node (TEST) for the uv unwrapped cube.
In material the texture node is still selected, cube selected in object mode.
Render tab go to Bake and hit Bake with Bake Type: combined
Related Objects
Mentioned Here
rB6f92604e539b: OpenGL render: Move file writing to a separate thread
Symen (Symen) created this task.Oct 18 2016, 12:40 PM
Symen (Symen) raised the priority of this task from 90 to Unbreak Now!.Oct 18 2016, 12:55 PM
Symen (Symen) added a project: Cycles.
Sergey Sharybin (sergey) closed this task as a duplicate of T48225: Can't bake textures with GPU on Macbook Pro (AMD Card).Oct 18 2016, 12:55 PM
