Maniphest T51422
UV / Image Editor's Proportional Edit (Connected) doesn't take edge connections into account.
Closed, ResolvedTO DO
Demeter Dzadik (Mets)
Adam Preisler (Alphisto)
May 5 2017, 9:43 PM
  • BF Blender
  • Good First Issue
  • UV Editing
Denis Declara (decden)
Eugene Du (APEC)
Germano Cavalcante (mano-wii)
Habib Gahbiche (zazizizou)
Julia Maliauka (julia-coffee)
2 More Subscribers
Broken: 2.78
Bug Description
When Proportional Edit (Connected) is active, the same translation of a vertex in 3D View doesn't equal UV / Image Editor's translation of the same vertex.
UV / Image Editor doesn't take distance by edge into account (only checks if it's an island).
Both movements should be like seen in 3D View.
  • Open the File
  • Try to move the selected vertex in both 3D View and then in UV / Image Editor
Adam Preisler (Alphisto) created this task.May 5 2017, 9:43 PM
mathieu menuet (bliblubli) lowered the priority of this task from 90 to 50.Jun 2 2017, 7:08 AM
mathieu menuet (bliblubli) added a subscriber: mathieu menuet (bliblubli).
I can confirm the bug.
Denis Declara (decden) added a subscriber: Denis Declara (decden).Oct 2 2017, 12:53 PM
Brecht Van Lommel (brecht) added a subscriber: Lucas Boutrot (thornydre).
Demeter Dzadik (Mets) added a subscriber: Demeter Dzadik (Mets).Aug 3 2019, 2:23 AM
I don't even have the option for connected proportional editing in the UV editor anymore, am I just being an idiot? Or was it removed until this gets fixed? Or was it removed with no intention of coming back?
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:36 PM
Germano Cavalcante (mano-wii) mentioned this in T63731: Modeling Module.Jan 16 2020, 1:41 PM
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "To Do".Jan 16 2020, 1:44 PM
Germano Cavalcante (mano-wii) removed a project: Tracker Curfew.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
This works as designed (only considers islands), but would be interesting to implement.
Marking as To Do
Habib Gahbiche (zazizizou) added a subscriber: Habib Gahbiche (zazizizou).May 9 2020, 3:07 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Medium Term on the Modeling board.Jun 17 2020, 4:40 AM
Campbell Barton (campbellbarton) added a project: Good First Issue.Jun 17 2020, 4:42 AM
Campbell Barton (campbellbarton) edited projects, added UV Editing; removed Modeling.Jun 17 2020, 1:55 PM
Campbell Barton (campbellbarton) moved this task from Backlog to Long Term on the UV Editing board.Jun 17 2020, 1:57 PM
Kenneth Y (Microbob) added a subscriber: Kenneth Y (Microbob).EditedJun 25 2020, 10:04 PM
I'm new to blender dev and I'm interested to take a look into this issue.
I've just tested the OP's blender file in blender 2.83.1 and 2.90 alpha (I do see the issue is listed to be broken in 2.78) and I've found a couple of things
  1. The UV unwrapped mesh seems to be incredibly small compared to the edit-mode version (the proportional editing circle is massive in the UV editor as compared to edit mode)
  2. The connected mode seems to be ignored in the UV editor
  3. The translations of the vertices seem to be the same, and I'm actually experiencing a different bug (what I listed above) than what the OP described when trying to reproduce
Please let me know if you have any tips for how to proceed, and if the bug is still there and I'm reproducing it incorrectly.
Thanks!
Eugene Du (APEC) added a subscriber: Eugene Du (APEC).Jun 29 2020, 10:38 AM
Julia Maliauka (julia-coffee) added a subscriber: Julia Maliauka (julia-coffee).Aug 7 2020, 6:39 PM
Hi everyone, I was able to confirm the bug in 2.83, but it looks like it's been fixed at some point in 2.91.0. Can anybody confirm that this is still an issue or should this task be closed?
And by fixed, I mean that the proportional edit mode's 'connected only' option seems to behave similarly in the UV editor as it does in the 3D view. There might be other translation issues that were not addressed.
Aaron Carlisle (Blendify) changed the task status from Confirmed to Needs Information from User.Aug 7 2020, 9:24 PM
Demeter Dzadik (Mets) closed this task as Resolved.Aug 8 2020, 2:47 PM
Demeter Dzadik (Mets) claimed this task.
This sounds like it must've been fixed by D8289 just a couple weeks back!
