Maniphest T52193
scale bug
Closed, Archived
Bastien Montagne (mont29)
daniel (midan)
Jul 26 2017, 12:48 PM
  • BF Blender
daniel (midan)
win7 64
Broken: edc6bec
when you rotate object in for example Y axis and then try to scale it by -1 in Y world axis it takes Y local axis instead of world Y axis. It does not happen while grabbing or rotating- you can grab or rotate in global and local coordinate and have expected result. scale does not work that way.
in attached file
there are 2 boxes rotated in X axis by -30deg. the right one has rotation applied.
try to scale left box in Y world axis by -1. it should be the same when you do it with right box.
Related Objects
Mentioned In
T68152: Scale Constraint by Axis does afect two axis on rotated Object
Mentioned Here
rBedc6bec9d602: PyAPI: Skip user scripts w/ factory-startup
daniel (midan) created this task.Jul 26 2017, 12:48 PM
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Jul 26 2017, 1:15 PM
Bastien Montagne (mont29) added a subscriber: Bastien Montagne (mont29).
Thanks for the report, but indeed, scale does not work that way! It is stored along (local) axes of the objects, so when those are not aligned with selected transform space, scaling is merely proportionally spread across all involved object's axes. What you’d expect is actually converting scaling into shearing, which is not supported - and goes way beyond simple scale tool anyway.
