Maniphest T52472
VSE Audio Volume not set immediately
Closed, Resolved
Joerg Mueller (nexyon)
Mark Ormston (Zolaerla)
Aug 20 2017, 10:53 PM
  • BF Blender
Bastien Montagne (mont29)
Windows 7 x64, GeForce GTX 980Ti
Broken:
Windows x64
Stable: v2.78c (Date: 2017-02-24 14:33)
Test Build v2.79 (Date: 2017-08-19 18:00)
Worked: Unknown
In the VSE, when adding an audio file or a video and setting the volume down, the volume is at 100% for a split moment before changing. This is only occasionally noticeable when previewing, but it is pretty much guaranteed when rendered to a video file.
I have tried delaying the audio by a few frames, but it seems to occur starting from the first frame the audio can be heard. Since I am making video with my voice in it, and loud videos are being used that need to be greatly reduced in volume (down to 0.1 usually), this is causing loud blips throughout the rendered video when switching source videos.
In the attached zip file, the .blend shows the problem. I want the volume of that very annoying ambient sound to be quiet (down to 0.1). When you render it, it is at full volume for a split moment before adjusting the volume.
Source Video: SoundProblem.avi - Loud, but there is no blip in it
Rendered Videos: Blender-SoundProblem (from [*Version*]) - A loud blip at the beginning before it is quieted down
I just want the audio to start at the volume I specified, instead of at full volume briefly before quieting down.
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T68945: VSE - Improper audio on frame 1 when exporting to lossy-compressed audio
rB514c9d14e4ab: Fix T68945: VSE - Improper audio on frame 1
Mark Ormston (Zolaerla) created this task.Aug 20 2017, 10:53 PM
Mark Ormston (Zolaerla) updated the task description.Aug 20 2017, 10:58 PM
Bastien Montagne (mont29) assigned this task to Joerg Mueller (nexyon).Aug 26 2017, 2:51 PM
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
Bastien Montagne (mont29) added subscribers: Joerg Mueller (nexyon), Bastien Montagne (mont29).
@Joerg Mueller (nexyon), care to check that one? Thanks.
Joerg Mueller (nexyon) changed the task status from Unknown Status to Resolved by committing rB8d207cdc3b30: Fix T52472: VSE Audio Volume not set immediately.Sep 1 2017, 12:28 PM
Joerg Mueller (nexyon) added a commit: rB8d207cdc3b30: Fix T52472: VSE Audio Volume not set immediately.
Joerg Mueller (nexyon) added a comment.Sep 1 2017, 12:37 PM
This is because audio volume changes are always faded and the initial volume is 1.0. The bugfix sets this initial volume to 0.0 so that it's more a fade in. Meanwhile you can try to set the mixdown "Accuracy" to lower values than 1024. This will make it take longer for the export (1 would take VERY long, I'd start with 128 and keep halving that) but if the first few samples of your sound file are not too loud, this can help.
Mark Ormston (Zolaerla) added a comment.Sep 16 2017, 11:28 PM
I have downloaded the release version of 2.79, and I am happy to say the problem has been completely resolved! Thank you!
Joerg Mueller (nexyon) mentioned this in rB514c9d14e4ab: Fix T68945: VSE - Improper audio on frame 1.Oct 3 2019, 10:27 AM
