Maniphest T53664
VSE Rotation is Backwards
Closed, ResolvedTO DO
None
Daniel Oakey (doakey3)
Dec 30 2017, 5:50 PM
  • BF Blender
  • Video Sequencer
Philipp Oeser (lichtwerk)
Arch Linux, Intel
2.79
VSE video rotation using transform effect is backwards.
  1. Add a transform effect to a video clip
  2. Rotate that video clip using the rotation property
Rotation in the 3d view behaves as expected (clockwise). Here we are rotating a cube 15 degrees:
Rotating a video clip by 15 degrees will rotate counter clockwise
Daniel Oakey (doakey3) created this task.Dec 30 2017, 5:50 PM
Campbell Barton (campbellbarton) added a subscriber: Campbell Barton (campbellbarton).Jan 2 2018, 11:51 AM
An issue with fixing this is it will break animated rotation. Maybe worth keeping this as a breaking change for 2.8x.
Christopher_Anderssarian added a project: Video Sequencer.Jan 3 2018, 5:18 PM
Philipp Oeser (lichtwerk) claimed this task.Jan 3 2018, 7:30 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to Normal.
Philipp Oeser (lichtwerk) edited a custom field.
will try to do this (for future inclusion in 2.8 maybe)
Philipp Oeser (lichtwerk) removed Philipp Oeser (lichtwerk) as the assignee of this task.Feb 4 2018, 10:24 PM
Unfortunately I'll only be able to look at this in April again, so let others take over....
Campbell Barton (campbellbarton) added a comment.Feb 5 2018, 2:05 AM
Note the compositor nodes rotation also works this way.
Daniel Oakey (doakey3) added a comment.Feb 5 2018, 4:20 AM
I took another look at this and realized I was confused. I noticed that in the 3d view, if I enter in a positive value for rotation, Blender will convert this value to a negative number (see the GIF). While I still think this is strange, there is no inconsistency with the video sequencer.
Campbell Barton (campbellbarton) added a comment.Feb 5 2018, 5:06 AM
3D view isn't related since you will get different results depending on the view direction.
Campbell Barton (campbellbarton) mentioned this in T54387: 2.8: Code-Quest (Topics we plan to cover).Mar 21 2018, 12:21 PM
Daniel Oakey (doakey3) changed the task status from Unknown Status to Resolved.Jan 2 2019, 9:34 PM
