Maniphest T53914
Transparency swallows volume scatter bounce
Closed, Resolved
None
Stefan Werner (swerner)
Jan 27 2018, 7:56 AM
  • BF Blender
  • Cycles
Brecht Van Lommel (brecht)
Derek Barker (lordodin)
Sergey Sharybin (sergey)
Thomas Dinges (dingto)
Valeri Barashkov (valera)
When a transparent surface penetrates a scattering volume, scatter rays can get stopped at the transparent surface instead of traversing it, regardless of the number of transparent bounces set in the render options.
See the attached file. The 100% transparent plane effectively cuts off volume scattering in the cube. The expected result is that a 100% transparent plane should have no visible influence on volume scattering.
Verified in Blender 2.79, master as of commit 7b29e917118ffdeb39de5c942dd652d40914dbc3 on macOS 10.13 and Windows 10.
I have a potential fix for this coming.
Revisions and Commits
rC Cycles
D3024
rB Blender
D3024
Stefan Werner (swerner) created this task.Jan 27 2018, 7:56 AM
Stefan Werner (swerner) changed the task status from Unknown Status to Resolved by committing rB3c852ba0741f: Fix T53914: Volumetric scattering now goes correctly through transparent….Jan 27 2018, 9:39 PM
Stefan Werner (swerner) added a commit: rB3c852ba0741f: Fix T53914: Volumetric scattering now goes correctly through transparent….
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 50.Jan 29 2018, 5:12 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
This commit is affecting many regression tests, and investigating it more closely I don't think it's correct, so I'll revert it for now to keep the tests passing. After this change it's no longer possible to get just direct volume lighting, it will always do at least 1 indirect volume bounce as well.
The same problem exists for diffuse or glossy bounces, the problem really is with volume emission (and mesh emission) for which we don't do any direct light sampling. Direct light shadow rays will go through the transparent surfaces to reach the emission, but indirect light rays will not.
I'm not sure yet what the right solution is.
Brecht Van Lommel (brecht) added a commit: rB282b3d0fcd0a: Revert "Fix T53914: Volumetric scattering now goes correctly through….Jan 29 2018, 5:12 PM
Brecht Van Lommel (brecht) changed the task status from Resolved to Unknown Status.Jan 29 2018, 5:13 PM
Stefan Werner (swerner) added a comment.Jan 30 2018, 9:13 AM
I see what you mean.
Just to make sure we're on the same page: Intended behaviour is that when max_volume_bounce is set to 0, we trace one scatter event inside the volume from which we gather emission inside the volume, but not any direct or indirect light? So volume emission will illuminate volume scattering, but not other surfaces (since we don't have next event estimation for volume emission)? And once we get next event estimation for volumes emission, it should then also illuminate surface shaders too?
Brecht Van Lommel (brecht) added a comment.EditedJan 30 2018, 10:01 AM
The intended behavior is that when max_volume_bounce is 0, we gather direct lighting and emission from surfaces and volumes. The latter is also considered to be "direct lighting", so that a mesh light behaves the same as any other light. Using next event estimation or not should not make any difference in the converged render result, but it is different in this case due to an inconsistency with the handling of transparent surfaces.
If you run the regression tests you'll see the difference, but here's an example where you can see how surfaces and volume handle indirect light differently after the fix:
Before FixAfter Fix
Max surface and volume bounces 0
Max surface and volume bounces 1
Currently I'm thinking the fix could be something like this:
  • Move the max bounces test into path_state_next(), setting a state->flag to indicate the path is to be terminated.
  • If that flag is set shader evaluation at the next bounce will remove all closures except for emission and transparency (or not add them in the first place: D2938).
  • The path can then continue for transparency but not other BSDF/BSSRDF types.
Maybe there's a simpler way to do it, I'm not sure.
Stefan Werner (swerner) added a comment.Jan 31 2018, 12:16 AM
That sounds like a good approach. I suspect that in general, transparent intersections can lead to incorrect path termination. Note how for example how an environment light with diffuse bounces = 0 will not provide direct illumination through transparency. Volume emission currently also provides direct light to surfaces inside the volume's bounds, but not to surfaces outside of the volume's bounds.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved by committing rC177afacea6d6: Fix T53914: Volumetric scattering now goes correctly through transparent….Feb 13 2018, 3:25 PM
Sergey Sharybin (sergey) added a commit: rC177afacea6d6: Fix T53914: Volumetric scattering now goes correctly through transparent….
Sergey Sharybin (sergey) added a commit: rC62f3a631d40c: Revert "Fix T53914: Volumetric scattering now goes correctly through….
Brecht Van Lommel (brecht) changed the task status from Resolved to Unknown Status.Feb 19 2018, 5:03 PM
This shouldn't have been closed yet.
Brecht Van Lommel (brecht) added subscribers: Derek Barker (lordodin), Thomas Dinges (dingto), Sergey Sharybin (sergey).
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Resolved by committing rB2d81758aa650: Cycles: better path termination for transparency..Feb 22 2018, 12:59 AM
Brecht Van Lommel (brecht) added a commit: rB2d81758aa650: Cycles: better path termination for transparency..
Sergey Sharybin (sergey) added a commit: rC23fa049ad239: better path termination for transparency.Feb 27 2018, 4:40 PM
Valeri Barashkov (valera) added a subscriber: Valeri Barashkov (valera).Oct 7 2020, 10:31 PM
This bug is still present in 2.90.1, do I need to submit a new bug report or will this one be re-opened?
Brecht Van Lommel (brecht) added a comment.Oct 8 2020, 2:41 PM
We don't reopen old bug reports, a new one should be submitted since it's likely a different cause.
