Using an empty as a reference object to specify the texture coordinates only results in 1/4 of the area being used.
The empty is 3/4 bigger than the area that's being textured.
Best open the blend file to see for your self.
Blender 2.79 on Windows 8
| Brecht Van Lommel (brecht) |
| Niels Philipsen (NP) | |
| Feb 15 2018, 4:44 PM |
| Carlo Andreacchio (candreacchio) |
| Sergey Sharybin (sergey) |
The texture that you can see in the render is in fact the entire texture, its not being cut off its being scaled. I will upload another blendfile with a blurry circle texture, this will better illustrate the problem.
The expected behaviour would be to have the texture fit within the bounds of the empty, not just 1/4th of the bounds. This was also the original behaviour of using an empty in the materials for the older Internal renderer.
