Maniphest T54086
Can't start blender
Closed, Archived
Vuk Gardašević (lijenstina)
Mathieu brocas (kirosbr)
Feb 16 2018, 1:57 PM
  • BF Blender
Brecht Van Lommel (brecht)
Min Yin (sakkaku)
Linux manjaro
AMD R9
Broken: Blender 2.79
When i start blender, i have a direct core_dump
Start blender
Blender 2.79 (sub 2), Commit date: 2018-02-16 09:42, Hash 8dfe9ef4e3c
backtrace
blender(BLI_system_backtrace+0x34) [0x55b2deb7f224]
blender(+0xa5ba65) [0x55b2de15ca65]
/usr/lib/libc.so.6(+0x348e0) [0x7f39e623a8e0]
/usr/lib/libdrm_amdgpo.so.1(amdgpu_get_marketing_name+0xc) [0x7f39a5748994]
/usr/lib/libamdocl64.so(+0xc08761) [0x7f39a817f761]
/usr/lib/libamdocl64.so(+0xc08d0f) [0x7f39a817fd0f]
/usr/lib/libamdocl64.so(+0xc0b769) [0x7f39a8182769]
/usr/lib/libamdocl64.so(+0xbeb708) [0x7f39a8162708]
/usr/lib/libamdocl64.so(+0x84d747) [0x7f39a7dc4747]
/usr/lib/libamdocl64.so(+0xc15d29) [0x7f39a818cd29]
/usr/lib/libamdocl64.so(+0xc15d9f) [0x7f39a818cd9f]
/usr/lib/libamdocl64.so(+0xc16b27) [0x7f39a818db27]
/usr/lib/libamdocl64.so(+0x80729a) [0x7f39a7d7e29a]
/usr/lib/libamdocl64.so(+0x8087a7) [0x7f39a7d7f7a7]
/usr/lib/libamdocl64.so(+0x808936) [0x7f39a7d7f936]
/usr/lib/libamdocl64.so(+0x7ed717) [0x7f39a7d64717]
/usr/lib/libamdocl64.so(clIcdGetPlatformIDsKHR+0xa2) [0x7f39a7d315a2]
/usr/lib/libOpenCL.so(+0x5d1e) [0x7f39abcdad1e]
/usr/lib/libOpenCL.so(clGetPlatformIDs+0x115) [0x7f39abcdcc15]
blender(_ZN3ccl18device_opencl_infoERNS_6vectorINS_10DeviceInfoENS_16GuardedAllocatorIS1_EEEE+0x49) [0x55b2df09bf09]
blender(_ZN3ccl6Device17available_devicesEv+0x219) [0x55b2df06b6b9]
blender(+0x187025a) [0x55b2def7125a]
/usr/lib/libpython3.6m.so.1.0(_PyCFunction_FastCallDict+0x90) [0x7f39ece13ad0]
/usr/lib/libpython3.6m.so.1.0(+0x184d1b) [0x7f39ece39d1b]
/usr/lib/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0x30a) [0x7f39ecdcdb5a]
/usr/lib/libpython3.6m.so.1.0(PyEval_EvalCodeEx+0x318) [0x7f39ece3a2c8]
/usr/lib/libpython3.6m.so.1.0(+0x151674) [0x7f39ece06674]
/usr/lib/libpython3.6m.so.1.0(PyObject_Call+0x4b) [0x7f39ece1deeb]
blender(+0xe9a5d3) [0x55b2de59b5d3]
blender(RNA_property_enum_items_ex+0x5b) [0x55b2de9e563b]
blender(RNA_property_enum_items+0x14) [0x55b2de9e56d4]
blender(RNA_property_enum_value+0x33) [0x55b2de9e5a13]
blender(+0xe8a462) [0x55b2de58b462]
blender(+0xe8aff4) [0x55b2de58bff4]
/usr/lib/libpython3.6m.so.1.0(PyObject_SetAttr+0x88) [0x7f39ece644e8]
/usr/lib/libpython3.6m.so.1.0(_PyEval_EvalFrameDefault+0xae2) [0x7f39ecdce332]
blender(bpy_app_generic_callback+0xad) [0x55b2de5969fd]
blender(BLI_callback_exec+0x2d) [0x55b2deb3fa9d]
blender(WM_init+0x262) [0x55b2de16ea22]
blender(main+0x29a) [0x55b2de14049a]
/usr/lib/libc.so.6(__libc_start_main+0xea) [0x7f39e6226f4a]
blender(_start+0x2a) [0x55b2de1594ca]
Related Objects
Mentioned Here
T56791: OpenCL has stopped working
rB8dfe9ef4e3ca: Fix bplayer (c)
Mathieu brocas (kirosbr) created this task.Feb 16 2018, 1:57 PM
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Feb 16 2018, 2:06 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
It seems to be crashing in the AMD OpenCL code. Please try running clinfo from the command line (install package if needed) and attach its output here, so we can see the exact OpenCL implementations and versions installed.
If clinfo crashes as well, it means your OpenCL installation is broken in some way, and even if it doesn't there may well be something broken in it. It can help to uninstall all OpenCL implementations (AMD, NVIDIA, pocl, beignet, ..), see if Blender runs then, and only install the ones you really need again. Also installing the latest AMD driver version may help.
Vuk Gardašević (lijenstina) changed the task status from Unknown Status to Unknown Status.Feb 24 2018, 9:22 PM
Vuk Gardašević (lijenstina) claimed this task.
Vuk Gardašević (lijenstina) added a subscriber: Vuk Gardašević (lijenstina).
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
Min Yin (sakkaku) added a subscriber: Min Yin (sakkaku).Sep 10 2018, 3:08 PM
I have a very similar error. I am on Arch Linux with an AMD RX 580. Using the latest AMDGPU version 18.0.1-2 from Arch Linux and opencl-amd 18.30.641594-1.
The error happens when I change to Cycles Renderer or go to Settings > System. Error Message:
amdgpu_device_initialize: amdgpu_query_info(ACCEL_WORKING) failed (-9)
Writing: /tmp/blender.crash.txt
Segmentation fault (core dumped) dumped)
Blender Crash Log attached.
I think AMD GPU Rendering seems to have a problem. Because when I uninstall opencl-amd, everything works fine. Probably because CPU Rendering is used. OpenCL does not seem to be broken, I get an output on clinfo
Brecht Van Lommel (brecht) added a comment.Sep 14 2018, 11:27 AM
See T56791 for a newer task on this error, let's continue there.
