Maniphest T54108
Child Of vertex group fails when controled by Particle System
Confirmed, LowKNOWN ISSUE
None
Serge Lyatin (SergeL)
Feb 20 2018, 5:29 PM
  • BF Blender
  • Animation & Rigging
  • Physics
Brecht Van Lommel (brecht)
Joshua Leung (aligorith)
Philipp Oeser (lichtwerk)
Sybren A. Stüvel (sybren)
Win10 64bit
Broken: 2.79
Child Of constraint fails on rotation from PS
Open file, play animation on every layer
First layer: Empty with Child Of constraint is controled by Plane's transform animation -> works OK
Second layer: Empties with Child Of are controled by Plane's Particle System (via Explode) -> Location is maintained, but rotation is non-synchronized
Third layer (example of how previous case is expected to work): Empties parented to 3 vertices are controled by same PS - OK
Serge Lyatin (SergeL) created this task.Feb 20 2018, 5:29 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Apr 27 2018, 9:50 AM
Sorry this report hasnt been answered in quite a while.
Just to be sure:
I see a difference in layers 2 and 3:
  • for me layer 2 shows empties following face orientation (Z-axis is sticking to the facenormal correctly, but rotation around Z is sliding)
  • layer 3 shows empties with Z-axis is sticking to the facenormal correctly, and rotation around Z is not sliding
So we are talking about the (sliding around Z-Axis) rotation in layer 2, right?
Serge Lyatin (SergeL) added a comment.Apr 27 2018, 10:00 AM
Yeah, rotation sliding on Z is bothering me
Philipp Oeser (lichtwerk) added a comment.Apr 27 2018, 10:32 AM
OK, will have a look
Philipp Oeser (lichtwerk) claimed this task.Apr 27 2018, 4:11 PM
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.
Philipp Oeser (lichtwerk) added a subscriber: Joshua Leung (aligorith).
This doesnt seem to be related to a ParticleSystem in particular.
It just works well with object transformations on the target (same as your First Layer example), but not so well with object data transformations...
Here is a simpler testcase:
  • select plane, rotate in objectmode -> constraint works as expected
  • go into editmode (all verts selected), rotate them all --> constraint shows issue described above
Will check whats going on in contarget_get_mesh_mat() later, but also getting @Joshua Leung (aligorith) on board [in case this is real simple for him?]
Philipp Oeser (lichtwerk) removed Philipp Oeser (lichtwerk) as the assignee of this task.Mar 28 2019, 8:52 PM
Philipp Oeser (lichtwerk) added subscribers: Campbell Barton (campbellbarton), Brecht Van Lommel (brecht).
Checked this again and atm it just averages positions and normals of participating verts.
A rotation is derived from the resulting averaged normal alone - thus not being 'stable'.
While I guess it is possible to improve the situation (at least if enough verts are actually in the group -- then by constructing a virtual tri and doing something similar to ob_parvert3?),
I would first like to check if this is considered a bug, or if should be postponed as TODO?
@Campbell Barton (campbellbarton), @Brecht Van Lommel (brecht): opinions?
[stepping down from this for the time being... sorry this has been on my desk for so long without results...]
Brecht Van Lommel (brecht) lowered the priority of this task from 50 to Low.Apr 2 2019, 7:12 PM
Not sure about the right behavior, would consider quite low priority.
Dalai Felinto (dfelinto) added a project: Tracker Curfew.Dec 23 2019, 4:36 PM
Sybren A. Stüvel (sybren) changed the subtype of this task from "Report" to "Bug".Jan 20 2020, 10:52 AM
Sybren A. Stüvel (sybren) added a subscriber: Sybren A. Stüvel (sybren).
This is inherently limited, as there are infinitely many rotations that map one vector onto another one. As such this is a design limitation, and I'll mark this as Known Issue.
Sybren A. Stüvel (sybren) removed a project: Tracker Curfew.Jan 20 2020, 11:27 AM
Brecht Van Lommel (brecht) changed the subtype of this task from "Bug" to "Known Issue".Jan 20 2020, 2:40 PM
I guess it was accidentally changed to the wrong subtype then.
Sybren A. Stüvel (sybren) moved this task from Backlog to Known Issues on the Animation & Rigging board.Feb 17 2020, 5:51 PM
