Maniphest T54360
FFMPEG bitrate not editable for all codecs
Closed, Resolved
Sybren A. Stüvel (sybren)
David Rylander (animationista)
Mar 19 2018, 1:36 PM
  • BF Blender
  • Render Pipeline
Christopher_Anderssarian
Ubuntu 17.10
Nvidia GeForce GTX 580
Broken: 2.79 5bd8ac9cbfa
Worked: 2.78 3c043732d3f
After the remake of the Encoding settings in Render tab the Rate: settings is greyed out and non editable.
If a blend is saved in 2.78, with custom bitrate set, that file is opened as normal editable in 2.79, but any additional scenes created there have greyed out rate settings.
(Tested with 2.79 and 2.79a, default settings and startup scene)
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T54255: 2.79b release
Mentioned Here
rB3c043732d3f5: Blender 2.78b: Point addons to an updated revision
David Rylander (animationista) created this task.Mar 19 2018, 1:36 PM
Brecht Van Lommel (brecht) renamed this task from Rate: settings non editable to FFMPEG bitrate not editable for all codecs.Mar 19 2018, 8:02 PM
Brecht Van Lommel (brecht) assigned this task to Sybren A. Stüvel (sybren).
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 50.
Christopher_Anderssarian added a subscriber: Christopher_Anderssarian.Mar 19 2018, 8:34 PM
As a quick workaround, you can select a codec that has a Constant Rate Factor (CRF) labeled 'Output quality' (e.g. H.264) set it to 'None; use constant bit-rate' and switch back.
Sybren A. Stüvel (sybren) changed the task status from Unknown Status to Resolved by committing rBcfe43f8d1af2: Fix T54360: FFMPEG bitrate not editable for all codecs.Mar 22 2018, 2:48 PM
Sybren A. Stüvel (sybren) added a commit: rBcfe43f8d1af2: Fix T54360: FFMPEG bitrate not editable for all codecs.
Sybren A. Stüvel (sybren) mentioned this in T54255: 2.79b release.Mar 22 2018, 3:02 PM
