Maniphest T54408
Blender stops responding/crashes If I don't start It from the "cmd"
Closed, Archived
Ray Molenkamp (LazyDodo)
aaa aaa (StarK3662)
Mar 23 2018, 9:44 PM
  • BF Blender
aaa aaa (StarK3662)
Bastien Montagne (mont29)
Christopher_Anderssarian
Sergey Sharybin (sergey)
Vuk Gardašević (lijenstina)
  • Win10 Pro 64 bit
  • Intel(R) Core(TM) i5-7300HQ CPU 2.50GHz
  • NVIDIA GeForce 1050 and Intel(R) HD Graphics 630
  • 8GB Ram
Broken: 2.79.a, 2018-02-21 10:41
Worked: same build*
When launch Blender from Steam or from the directory it crashes/stops responding few seconds after it. *But It Works if you launch it from "cmd".
I deleted Blender and reinstalled it from Steam, this might be releated but I am not sure.
  • I am adding a video to clarify
edit after submitting prematurely
aaa aaa (StarK3662) created this task.Mar 23 2018, 9:44 PM
Vuk Gardašević (lijenstina) changed the task status from Unknown Status to Archived.Mar 23 2018, 10:17 PM
Vuk Gardašević (lijenstina) claimed this task.
Vuk Gardašević (lijenstina) added a subscriber: Vuk Gardašević (lijenstina).
This report is empty.
Please, if you want to report bugs follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here:
https://wiki.blender.org/index.php/Dev:Doc/Process/Bug_Reports
Closing as Invalid.
aaa aaa (StarK3662) renamed this task from Blender Stops Responding/Crashed to Blender stops responding/crashes If I don't start It from the "cmd".Mar 23 2018, 10:18 PM
aaa aaa (StarK3662) changed the task status from Archived to Unknown Status.
aaa aaa (StarK3662) claimed this task.
aaa aaa (StarK3662) lowered the priority of this task from 90 to Normal.
aaa aaa (StarK3662) updated the task description.
aaa aaa (StarK3662) updated the task description.Mar 23 2018, 10:23 PM
aaa aaa (StarK3662) removed aaa aaa (StarK3662) as the assignee of this task.Mar 23 2018, 10:29 PM
Christopher_Anderssarian triaged this task as 90 priority.Mar 23 2018, 10:43 PM
Christopher_Anderssarian added a subscriber: Christopher_Anderssarian.
Don't Triage tasks yourself.
and sorry but your video has to go; as it contains copyrighted material...
@Vuk Gardašević (lijenstina) can you do this?
Ray Molenkamp (LazyDodo) added a subscriber: Ray Molenkamp (LazyDodo).EditedMar 24 2018, 12:17 AM
Its highly likely that this bug is specific to your hardware/driver configuration. These kinds of display issues are often caused by OpenGL driver bugs.
While its possible a software error in Blender, its worth checking if this functions correctly...
After upgrading graphics card drivers.
On a different system (with different hardware/drivers).
Using a Software OpenGL renderer...
On Linux/macOS, Official releases come with blender-softwaregl
On MS-Windows: Download this dll and copying it so its located in the same directory as 'blender.exe' and run Blender normally.
If this is a driver bug, or we can't link to this to an error in Blender's code, the report may be closed as a driver error, so please help us determine whether this is a bug in Blender or not.
I assume you are objecting to to the music? we can only remove the embed from the starting post, an actual admin has to delete the attachment from the server. paging @Sergey Sharybin (sergey) or @Bastien Montagne (mont29) can either of you help here?
Ray Molenkamp (LazyDodo) lowered the priority of this task from 90 to 30.Mar 24 2018, 12:17 AM
Ray Molenkamp (LazyDodo) added subscribers: Bastien Montagne (mont29), Sergey Sharybin (sergey).Mar 24 2018, 12:21 AM
Christopher_Anderssarian added a comment.Mar 24 2018, 9:15 AM
Yes, I mean if we can't post screenshots of other software, I would think copyrighted music falls under things we can't post.
And thanks for the insight.
aaa aaa (StarK3662) added a comment.Mar 25 2018, 1:49 PM
@Ray Molenkamp (LazyDodo) It gives 3 fps but fixes the crashing issue.
Ray Molenkamp (LazyDodo) changed the task status from Unknown Status to Unknown Status.Mar 25 2018, 3:52 PM
Ray Molenkamp (LazyDodo) claimed this task.
Seems like a driver bug then, try updating your drivers, i also seen people with a similar setup have an option somewhere to select the gpu to run a specific application on. either way doesn't seem to be a bug in blender.
