Maniphest T54437
Sequencer preview uses last updated scene
Closed, Resolved
Dalai Felinto (dfelinto)
Clément Foucault (fclem)
Mar 27 2018, 3:30 PM
  • BF Blender: 2.8
  • Video Sequencer
Sergey Sharybin (sergey)
Broken : dff7f55cd069 (2.8 HEAD)
Worked : unknown
The Scene strip preview always use the last updated scene - updating the a scene (changing a scene setting) breaks the sequencer preview and makes this scene render instead of the one specified in the Scene Strip.
You can recreate this file from scratch by adding a new scene, and adding a scene strip in the VSE.
  • Tweak scene exposure
  • Change current frame
Extra notes
Surprisingly, the render engine is always the one from the Scene Strip scene, even if another scene is rendered.
Related Objects
Mentioned In
rB26b9c502edce: Merge remote-tracking branch 'origin/master' into blender2.8
rB9f60c850f999: Depsgraph: initialize EvaluationContext even if nothing to update
T54438: Sequencer Scene preivew Color Management is broken
Mentioned Here
P648 (An Untitled Masterwork)
rBdff7f55cd069: GPUFramebuffer: Fix compiler warning about return value.
Clément Foucault (fclem) lowered the priority of this task from 90 to 50.Mar 27 2018, 3:30 PM
Clément Foucault (fclem) created this task.
Clément Foucault (fclem) updated the task description.Mar 27 2018, 3:34 PM
Clément Foucault (fclem) mentioned this in T54438: Sequencer Scene preivew Color Management is broken.
Christopher_Anderssarian added a project: Video Sequencer.Mar 28 2018, 4:15 PM
Dalai Felinto (dfelinto) added a comment.Mar 29 2018, 1:11 PM
More info: For testing changing color management exposure should be enough to trigger the bug, however you also need to change the frame to see the issue.
Also I animated the file, and now I can no longer reproduce the issue with it (the original file still has the bug, obviously):
Dalai Felinto (dfelinto) added a subscriber: Sergey Sharybin (sergey).Mar 29 2018, 1:37 PM
While --enable-copy-on-write will assert if you try opening this file (P648 if @Sergey Sharybin (sergey) is interested), when re-creating from scratch the error is still there.
Dalai Felinto (dfelinto) updated the task description.Mar 29 2018, 1:42 PM
Dalai Felinto (dfelinto) mentioned this in rB9f60c850f999: Depsgraph: initialize EvaluationContext even if nothing to update.Mar 29 2018, 3:34 PM
Dalai Felinto (dfelinto) mentioned this in rB26b9c502edce: Merge remote-tracking branch 'origin/master' into blender2.8.Mar 29 2018, 3:38 PM
Dalai Felinto (dfelinto) changed the task status from Unknown Status to Resolved.Apr 2 2018, 11:57 PM
Fixed on rB26b9c502edce and in rB9f60c850f999.
